battery charging rates
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> battery charging rates
Page: [1]
Login
battery charging rates - 6/2/2008 12:10:28 AM
02ram4by4
Status: offline
Hi How many amps should I charge a 4200 mah nimh battery that is new and a 1800 nicd battery.
Thanks Dave
       Post #: 1
RE: battery charging rates - 6/2/2008 12:36:30 AM
tail strike
Status: online
quote:
ORIGINAL: 02ram4by4
Thanks Dave
500 & 200
_____________________________
I am watching you
Larry S
(in reply to 02ram4by4)
       Post #: 2
RE: battery charging rates - 6/2/2008 4:36:48 PM
wcmorrison
Status: online
I would think "500 and 200" amperes will burn the batteries up. If you mean 500 and 200 milliamperes well that is different, isn't it? Big difference really. I think all of us did understand the question and you did give a viable answer, except for clarification on the amount of current - Amperes versus Milliamperes.
Cheers,
Chip
(in reply to tail strike)
       Post #: 3
RE: battery charging rates - 6/2/2008 4:45:27 PM
Rodney
Status: offline
For either NiCad or NiMh, the first charge should be for 16 hours at 0.1C. It may take up to three cycles of this forming charge to bring them up to full capacity. Discharge down to 0.9 volts/cell at not greater than .25C between charges during these forming cycles. Once the forming is complete, then it is quite safe to charge at up to 1C if you are using a peak detecting charger. If not a peak detecting charger, watch the temperature closely and as soon as you detect a significant rise in temperature, stop the charge.
(in reply to wcmorrison)
       Post #: 4
RE: battery charging rates - 6/2/2008 4:58:09 PM
rckt_mtrspts
Status: offline
quote:
ORIGINAL: 02ram4by4
Thanks Dave
Though I see it often confused or bad advice given, a good rule of thumb to follow is 1Amp chage rate per 1000mah of battery pack maximum. So charge a 1800 pack at 1.8A (max), though I tend to charge smallish packs at 1.0 to be safe and to prolong pack life, charge a 33000mAh pack at 3.3A, and charge your 4200 at 4.2A
RTR does not translate in any language to ''''Ready-To-Race''''
       Post #: 5
RE: battery charging rates - 6/2/2008 5:30:30 PM
02ram4by4
Status: offline
Thanks everyone I also have the Tekin bc112 c cahrger. Also I don't mean to sound dumb but what does 1c mean
Thanks Dave
< Message edited by 02ram4by4 -- 6/2/2008 5:35:18 PM >
(in reply to rckt_mtrspts)
       Post #: 6
RE: battery charging rates - 6/2/2008 5:34:24 PM
SavageX78
Status: offline
quote:
ORIGINAL: 02ram4by4
Thanks everyone I also have the Tekin bc112 c cahrger. Also I don't mean to sound but what it 1c mean
Thanks Dave
1c would be battery capacity divided by 10.
So if you have a 4200MaH battery a 1c charge rate would be 4.2 amps.
RCs : XXX-T MF2 ~ Xray M18 ~ Micro-T~ E-maxx 3905 ~ Mardave Cobra ~ Old Lunchbox (needs Restoration)
       Post #: 7
RE: battery charging rates - 6/2/2008 6:13:43 PM
Red Scholefield
Status: offline
quote:
ORIGINAL: MF2MM5700
quote:
ORIGINAL: 02ram4by4
Thanks Dave
NO, 1C is the battery capacity. In the above case the charge would be 4200 mA or 4.2 amps. The battery capacity divided by 10 or C/10 would be the overnight charge rate, or formaing charge rate for new cells.
Red S.
AMA 951 Leader Member
(in reply to SavageX78)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.672RCU1
