Which GRP on truggy?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Truggy >> Which GRP on truggy?
Page: [1]
Login
Which GRP on truggy? - 6/2/2008 1:07:20 PM
kubson_jammin
Status: offline
Hey ,
I want buy second engine for my x1x crt , now I have OS V-spec(it have enough power) , but I need second engine.
And now :
Grp .21 have great fuel economy , but it is powerful enough?
Grp .28 I dont know anything about economy of this engine , power is same as ninja .28.
So which is better for truggy?
       Post #: 1
RE: Which GRP on truggy? - 6/2/2008 1:14:47 PM
IL2mSturmovik
Status: offline
The .21 should be ample unless you have enormous open tracks, I run a Ninja 21 in my 8T and its smokin fast
_____________________________
LST2 tricked out LRP Spec 3 racer, 8ight-T with 21 Ninja power
(in reply to kubson_jammin)
       Post #: 2
RE: Which GRP on truggy? - 6/2/2008 3:40:55 PM
rebelracer246
Status: offline
what kinda track do you have a big open or a small close track?
http://www.youtube.com/watch?v=B6nJCigwtps
(in reply to IL2mSturmovik)
       Post #: 3
RE: Which GRP on truggy? - 6/2/2008 6:31:26 PM
K_B
Status: offline
A buddy has the Ninja 28 in an 8T and that thing is just silly fast with tons of bottom end to boot. A total blast to drive. It was getting about 8 minutes to a tank. If it were me, just judging by how much power that .28 had, a .21 should suit you just fine. The 28 seems like overkill unless you're running on big tracks like the Nitro Pit or something
Anchorage Radio Operated Auto Racing
http://www.aroararacing.org
(in reply to rebelracer246)
       Post #: 4
RE: Which GRP on truggy? - 6/2/2008 6:57:58 PM
rckt_mtrspts
Status: offline
Though I tried a .28 briefly it has been my experience that anything short of running on a track with really sticky or deep dirt that a .21 is all the motor you need and just as fast as a larger one as 21s are higher revving. But the big advantage I've noticed is compared to any of my buddies running bigblocks is that I get about 10-15% better fuel mileage.
RTR does not translate in any language to ''''Ready-To-Race''''
       Post #: 5
RE: Which GRP on truggy? - 6/2/2008 7:38:22 PM
IL2mSturmovik
Status: offline
quote:
ORIGINAL: K_B
The Ninja/GRP 28 is about th eonly 28 I would run in a truggy, its top end sacrifices nothing!
(in reply to K_B)
       Post #: 6
RE: Which GRP on truggy? - 6/2/2008 7:49:32 PM
Jerzferno
Status: offline
Saw my first GRP .21 engine run yesterday in a buggy. Tremendous torque. Gave him troubles in the turns. Broke the wheels loose very easy and caused him to spin and fish tail. Better throttle control once he gets used to it will help. It struggled a little on the long straight. But a little gearing adjustment should cure that. I was very impressed witht the engine. I didnt bring my buggy over to compare, but I have a .21 V-spec and I swear his engine looks HUGE.
We can rebuild it!
MARBETH Nitro Sports
       Post #: 7
RE: Which GRP on truggy? - 6/2/2008 10:06:06 PM
strngdze
Status: offline
I run the GRP .28. It's the first .28 I have ever tried as I have run .21's previously. I am extremely impressed at the broad range that this .28 produces power across. I can't wait to see the dyno on this thing to see if its just me or if this thing really has that broad of a powerband. I read all of the horror stories about .28's producing to much power and that you'll break the tires loose more then you'll hook up. This may be true with some, but I haven't found this to be the case on the GRP so far. It seems to have a real linear power delivery. I think GRP is onto to something here with regards to a new era of .28 mills. We'll see.
(in reply to Jerzferno)
       Post #: 8
RE: Which GRP on truggy? - 6/2/2008 10:26:01 PM
supertib
Status: offline
quote:
ORIGINAL: strngdze
that motor is the same as the Ninja 28.... it can be an animal depending on what pipe is used........the GRP pipes will severely choke those motors back and make them very mild....a GRP 28 on a GRP pipe will barely feel much stronger then a .21............... drop the GRP pipe and use a MSR 1005,053 or 086 and th emotor will make way more power and RPM..
seeing is believing !
(in reply to strngdze)
       Post #: 9
RE: Which GRP on truggy? - 6/2/2008 11:54:14 PM
stussman
Status: offline
Isnt the crt quite heavy compared to an eight? You might need a 28 to really pick up and haul a crt.
(in reply to supertib)
       Post #: 10
RE: Which GRP on truggy? - 6/6/2008 2:30:12 AM
gtsum
Status: offline
if you are happy with your vspec, you will love the grp21..it it has more then the vspec and has more then enough power for a truggy
(in reply to stussman)
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
