Digital Radio Problem
Tower Hobbies
Logged in as Guest
  Printable Version
JR R2000, JRPR2000 10CH RX, and JR Synth TX Module
Seller:  Erick Royer
Details:   $400.00   |  9/1/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Radio Equipment >> Digital Radio Problem
Page: [1]
Login
Digital Radio Problem - 6/3/2008 12:58:03 AM
zonda4life
Status: offline
I just bought a used jr xr3 radio. I got everything hooked up and the throttle servo operates perfectly but the steering servo is not working. It will only steer a little when turned left and it does not steer at all when turned right. This is my first digital radio but I have played around with the trims and travel adjustment with no success. I also swapped servos and receivers and the same thing happens. Im stumped any help is appreciated. Thanks!
       Post #: 1
RE: Digital Radio Problem - 6/3/2008 7:28:43 AM
systemlord
Status: offline
Before you ever install a servo arm, you must turn on the radio so the servo centers itself. Then you attach the servo arm, I had to reduce servo travel on both my steering & throttle servo. How much does the steering servo arm turn in degree's, most servos are 45 degree's. You can order gears to make them 90, 180 or 360 degree's.
_____________________________
UE SuperMaxx 1/8th Monster Truck* Custom Duratrax Vendetta Mamba 25 Motor 5400kv Impulse 3S1P 11.1v 950mAH 25C * Raptor 60
(in reply to zonda4life)
       Post #: 2
RE: Digital Radio Problem - 6/3/2008 6:19:05 PM
zonda4life
Status: offline
I'll admit I did turn on the radio without thinking about it, but I quickly turned it off and took off both servo arms so that the servos could center. I know that the steering servo is not damaged because if I plug it into the throttle input on the receiver it will operate normally! And if I plug the throttle servo into steering it will not turn right(pun?). Im not sure but it must not be the gears if the servo operates fine as the throttle. It seems very likely that it is a radio problem but I cannot figure it out. Thank you for the help.
(in reply to systemlord)
       Post #: 3
RE: Digital Radio Problem - 6/3/2008 7:32:50 PM
rcktpwrd
Status: offline
have you reset all the settings to factory spec?
sounds like the steering settings were set up for something specific and only allowing a certain limited amount of movement... noted by the same effect on both servos... try looking up the manual on JR's web site if you don't have one..
Joel
DuraTrax Raze; ''Monster'' Clod Tuber; Clod/TLT crawler; Kyosho NSR500; Marui Big Bear; Tamiya Fox
       Post #: 4
RE: Digital Radio Problem - 6/3/2008 11:17:33 PM
zonda4life
Status: offline
Yes I have reset it to default. It must be a defective radio I will have to send it in or try to return it. Thanks for the help though.
(in reply to rcktpwrd)
       Post #: 5
RE: Digital Radio Problem - 6/3/2008 11:23:29 PM
rcktpwrd
Status: offline
ahh... sounds like it might just be a defective radio or receiver...
maybe you can get it fixed under warranty
Joel
       Post #: 6
RE: Digital Radio Problem - 6/4/2008 3:05:26 AM
zonda4life
Status: offline
Yeah unfortunately the guy I bought it from claims it is set up for oval racing and this is why it won't turn right. I have reset it to factory settings and made sure the steering travel is set to 100% left and right..it hasn't changed.
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.393RCU1
