need help with GP Reactor
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> 3D Electric Flying! >> need help with GP Reactor
Page: [1] 2 3 4   next >   >>
Login
need help with GP Reactor - 6/3/2008 4:45:16 AM
summerwind
Status: offline
a friend of mine has got me hooked on getting into some electric flying. i am at current a four stroke hotdog, so what i'm asking might be becuase we gas flyers tend to over do thing s on the margin safety.
so i have decided on the GP Reactor for my first plane, and on Towers site they list the Futaba s3114's for servos. i am using Futaba FASST systems now.
the other item i'm wanting to make sure is going to be OK is the Rimfire motor they list which is the 35-30-1250.
in the reviews they used the Rimfire 35-30-950..........so as i know nothing about these motors, which one is the greater in power?
the other servos i had been looking at were Hitec's HS65's.....a bit heavier by a few grams, but look to be more durable than the Futaba S3114's, so i need your help here as well.
thx
mike
       Post #: 1
RE: need help with GP Reactor - 6/3/2008 5:04:02 AM
FoamyVictim
Status: offline
I believe the 3rd number basically represents the power band. A higher number makes more torque, and the lower is higher RPMs. Somebody correct me if I'm wrong.
The torque specs on both servos are pretty close. I've had the older, but similar servos in a flat foamy. They're pretty tough, strong and fast. I think they'd work well, and judging by the videos, they should do fine.
http://www.youtube.com/watch?v=0JjDk2X9wuM
(in reply to summerwind)
       Post #: 2
RE: need help with GP Reactor - 6/3/2008 2:34:22 PM
Doc Austin
Status: offline
quote:
ORIGINAL: summerwind
Send me a PM and I will tell you why this is a bad idea.
_____________________________
There are days when I believe one man can make a difference.....and others where I have given up all hope.
Matt Murdoc
       Post #: 3
RE: need help with GP Reactor - 6/3/2008 5:23:15 PM
summerwind
Status: offline
quote:
ORIGINAL: Doc Austin
i think you have the wrong idea here. i have been flying since '68 so it's not my first RC model.........but it will be my first electric.
(in reply to Doc Austin)
       Post #: 4
RE: need help with GP Reactor - 6/3/2008 10:02:06 PM
Hibrass
Status: offline
Summerwind,
I'm flying the Reactor Bipe with the 1250 rimfire and it is a great performer.. The 950 KV motor is a higher torque motor and will swing a bigger prop at a given voltage. The 1250 will swing a shorter higher pitch prop at a higher RPM at a given voltage...
I only have limited electric experiance as of now but short of my Larger Gas planes, Electrics will be the only small airplanes I buy again! Oh and the Bipe is a Riot to fly!
Good luck with your Reactor!
Ed "Hibrass" Harley Club Saito #457
"If you don't know the Dog, don't yank his chain."
       Post #: 5
RE: need help with GP Reactor - 6/4/2008 2:47:15 PM
summerwind
Status: offline
OK i have received a few PM's telling me not to buy this airplane as the wings fold up..............any other suggestions?
(in reply to Hibrass)
       Post #: 6
RE: need help with GP Reactor - 6/4/2008 3:06:19 PM
Hibrass
Status: offline
Summerwind,
The Reactor Bipe won't fold the wings... ;-) But if your looking for a single wing go check out the 3D Hobbyshop selection electric arobats.. The feedback has been great so far...
Good Luck,
       Post #: 7
RE: need help with GP Reactor - 6/5/2008 1:25:04 AM
FoamyVictim
Status: offline
Just started building mine:
       Post #: 8
RE: need help with GP Reactor - 6/5/2008 1:35:06 AM
summerwind
Status: offline
quote:
ORIGINAL: Hibrass
Summerwind,
Good Luck,
i like the bipe too.....so i ordered both.....the bipe and the single wing. thx
       Post #: 9
RE: need help with GP Reactor - 6/5/2008 8:55:52 AM
hellblastervolly
Status: offline
Hi Summerwind.
I have the single wing Reactor and never had a problem with the wings. Yes In the past there was a problem with the way the wing join together but they fix the problem plus lots of people didnt make sure that the wing to the fuse was making full contact. For the record I have the old version of it and did a lot of reserch to find what work and what didnt work with other reactor before I build mine. The plane fly awsome you will love it I have mine with Hitec HS65 for motor I have the E-flite Park 480 with APC 10x3.8 prop. You can go with the Rimfire 35-30-1250 or the one below but not the 950. If you have any question on building the reactor send me a pm and Ill help you to build it right.
P.S. I love the Bipe also I'll get one soon.
Fernando
" A Pilot Has To Do What A Pilot Has To Do To Fly "
       Post #: 10
RE: need help with GP Reactor - 6/5/2008 3:33:10 PM
FoamyVictim
Status: offline
I got some more done last night:
(in reply to hellblastervolly)
       Post #: 11
RE: need help with GP Reactor - 6/5/2008 4:21:45 PM
Hibrass
Status: offline
Foamy and others,
A little off topic, on about the Reactor Bipe... It does turn out a little tail heavy even with a 2100mah LiPo so keep that in mind. The balence points given does make it handle a little tail heavy... I like it like that but it is kind of a surprise at first.
Oh and watch your airleron throws. This thing will literally roll faster than you can control on max rates.. I crashed mine on maiden because I forgot to make sure I was in low rates for takeoff.
And speaking of crashing... The Reactor Bipe is one rugged bird for an electric, I only cracked the outer portion of the lower right wing during my crash and had it up and running after about an half an hour of work..
Good Luck,
(in reply to FoamyVictim)
       Post #: 12
RE: need help with GP Reactor - 6/5/2008 5:17:12 PM
FoamyVictim
Status: offline
Thanks for the heads up! I tend to be pretty anal about maidens. By the time it's on take off roll, I've checked and rechecked everything 5 times... Here's where I'm at now:
Now I have the tail feathers attached:
http://i304.photobucket.com/albums/nn200/l8ight/TailBuilt.jpg?t=1212682441
http://i304.photobucket.com/albums/nn200/l8ight/TailBuilt2.jpg?t=1212682465
       Post #: 13
RE: need help with GP Reactor - 6/6/2008 2:09:18 AM
FoamyVictim
Status: offline
Finally finished the build today, looked great. Took it to the field for a test flight. It flew great, until I got near the power lines. It glitched, and crashed. I could repair it, but I'm so bummed it'll prolly catch dust. I'll post pics tomorrow.
       Post #: 14
RE: need help with GP Reactor - 6/6/2008 3:25:04 AM
FoamyVictim
Po
