KentuckyColonel
CA, USA Status: online
All the above is good advise. Gear shim and/or lots of practice is the answer here, Throttle control is also a main key. take it easy on the roll up. Just run it up nice and easy, with full up on elevator. As you build speed, let up on the elevator. Continue to throttle up and the tail will rise, then when speed is enough, maybe a little kick of elevator to get her off the ground. Practice, practice, practice, then practice some more.
< Message edited by KentuckyColonel -- 6/4/2008 1:38:15 PM >
