McFly505
IN, USA Status: offline
If your X1 has resistance in the steering, then you have broken/binding parts in the steering/front suspension area. I had the same problem with mine and it turned out to be the steering rack/servo saver. Took it apart to find the rack was bent and the bearings were toast. Replaced the rack with a KHZ part and put the new servo saver in it. Problem solved. The next race, I noticed the same problem was happening again. Took it apart to find bent arms on the front hubs. Took the whole front suspension apart to find bent outer hinge pins and very dirty king pins/bushings. Cleaned and replaced everything in question. Haven't had any problems since. The king pins ride inside a steel sleeve in the c blocks. This area collects dirt and makes the steering bind up. Hard hits will bend/distort the aluminum hubs, making the steering bind, as well. Hope that helps. Scott
_____________________________
AE RC8-OS Speed, AE RC8-OS V Spec, AE RC8T-Coming soon!!!
