RE: Noorduyn Norseman by Vintage R/C    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Seaplanes >> RE: Noorduyn Norseman by Vintage R/C
Page: <<   < prev  1 [2]
Login
RE: Noorduyn Norseman by Vintage R/C - 9/16/2009 5:17 PM
bear 57
Score: 100
Last Login: 2/12/2012
Status: offline
Joel, I would sure be interested in some pictures of the front etc when you get the Saito fitted in. I am hedging between electric and a Saito 120. The electric is an easy fit while the Saito is going to require some re-engineering and delicate modifications.
Lorne
Hide Signatures
(in reply to yojoelay)
       Post #: 26
RE: Noorduyn Norseman by Vintage R/C - 9/16/2009 10:26 PM
yojoelay
Score: 105
Last Login: 5/20/2013
Status: offline
No worries.
I expect it would have been easier to do before assembly; since the firewall is already firmly attached it will be a dremel job. Will post pics once I get back into the plane.
All the best,
Joel
_____________________________
Maker of fine kindling
Hide Signatures
(in reply to bear 57)
       Post #: 27
RE: Noorduyn Norseman by Vintage R/C - 2/24/2011 7:06 PM
turttletoes02
Score: 100
Last Login: 4/16/2012
Status: offline
joel, where are you? i want to know how its going on that noorseman. what did you figure out for the engine? i paln on building one sometrime soon but am wondering how yours is going.
Hide Signatures
       Post #: 28
RE: Noorduyn Norseman by Vintage R/C - 2/24/2011 8:55 PM
yojoelay
Score: 105
Status: offline
Sorry Turtletoes2, the Norseman has been on hold for some time now. It is a beautiful looking plane and I'd recommend the cut kit as there is a lot of detail in the formers, ribs, etc. Family and work commitments have prevailed over building.
Joel
Hide Signatures
(in reply to turttletoes02)
       Post #: 29
RE: Noorduyn Norseman by Vintage R/C - 2/24/2011 10:20 PM
cam-flyer
Score: 100
Last Login: 5/18/2013
Status: offline
Joel,
I know how it is to start and put a plane on hold. I plan to get more stick time this year and just cut for others. Time to get the trainer out again!
Yours was the first kit I cut and several have been cut since then. There is a build going on at my forum that could use your help and support.
http://charlotteaircraftmodeling.com/topic.asp?TOPIC_ID=18
Good to hear you are still in the hobby!
Greg
Hide Signatures
       Post #: 30
RE: Noorduyn Norseman by Vintage R/C - 2/24/2011 11:52 PM
c550
Score: 110
Status: online
I have been following the build thread and have looked in to buying the parts, but I would like to know if there is a source for the cowl and windshields?
Regards,
Dave
Hide Signatures
(in reply to cam-flyer)
       Post #: 31
RE: Noorduyn Norseman by Vintage R/C - 2/25/2011 9:42 AM
yojoelay
Score: 105
Status: offline
I bought a vacuum formed cowl from Vintage RC. It is OK, a fiberglass one would be nicer but I don't know where you'd get one. I was just going to make the windshield.
Greg's cut kit is the way to go, it will make life a lot easier and he gives great support too.
Good luck,
Joel
Hide Signatures
(in reply to c550)
       Post #: 32
RE: Noorduyn Norseman by Vintage R/C - 2/26/2011 5:41 PM
turttletoes02
Score: 100
Status: offline
joel, do you have building instructions for the norseman? i have plans from vintage r/c plans but no building instruction if you have them where did you get them? if there out there somewhere i need to track them down. thanks.
jim.
Hide Signatures
       Post #: 33
RE: Noorduyn Norseman by Vintage R/C - 2/27/2011 5:40 AM
yojoelay
Score: 105
Status: offline
Sorry, I don't have instructions for it. Not sure where the plan was originally published - likely an older American magazine - maybe others would know.
I believe Greg showed the fuselage construction technique above and I have a few photos he sent me some time ago of the forward fuselage assembly - Greg, if you're happy for me to I'll dig them out and post them.
I had a look at Greg's forum and there are a few people building over there. I'm sure others around here will help you get it built if you run into trouble.
All the best,
Joel
Hide Signatures
       Post #: 34
RE: Noorduyn Norseman by Vintage R/C - 5/12/2011 1:11 AM
cam-flyer
Score: 100
Status: offline
Post your questions here and/or the CAMForum. At CAM we are in the process of pulling together builders to keep the hobby going and provide a resource over time.
Hide Signatures
       Post #: 35
RE: Noorduyn Norseman by Vintage R/C - 12/2/2012 7:37 PM
cam-flyer
Score: 100
Status: offline
The Norseman build has moved to the RCCanada Forum , please join the build.Charlotte Aircraft Modeling continue to support this build with a short kit.
Hide Signatures
       Post #: 36
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.453RCU1
