Tired Old Man
Joined: 2/25/2002 From: Central, CA, USA Status: offline
Carbon wing tube from Tom. Tail tube from TnT if they have them, saves about 4 grams..... Titanium axles from Don't Hobby Shop. Carbon main gear from Graphtec. The TnT and TBM gear are the same product. Carbon tailwheel leaf spring from Tom. Sullivan Skylite wheels. Wood prop, not carbon. Fiberglass spinner from Esprit Models. Leave the wheel pants off. By the time you're done you'll definately saved some weight at a cost of only about $75.00 an ounce Reality check. Replacing the wing tube, the wheels, and the spinner while using a wood prop are about the only practical items to play with. I only do the wing tube because carbon is stronger. Carbon gear is weaker due to incorrect lay up processes, incorrect material choices, and a lack of heat during the cure. If you don't go nuts with redundant batteries, switches, and receivers it's easy to end up with a 15 1/2 pound plane. It doesn't need to be any lighter than box stock to fly extremely well. Any lighter is just a personal thing.
_____________________________
If you can''''t fix it with a hammer, you have an electrical problem.
