Header Tank Question
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> Header Tank Question
Page: [1]
Login
Header Tank Question - 6/7/2008 3:20:41 PM
On The Patch!
Status: offline
Hi all!
I am installing a Saito 1.20 in a new Extra 330 I just got. I am planning to install a 2oz header-tank, and my question is:
Is the location of the main tank crucial if using a header? The problem I'm having is that the main will be located a lot lower down than the header and the carb, when the plane is upright. Inverted, the main would be about 2 inches higher up...
This is with the engine side-mounted, if I mount it inverted I get other kinds of problems such as cooling issues... I am planning to do quite a lot of 3d with the plane so equal fuel-supply would be important.
Any help would be much appreciated!
Johan
       Post #: 1
RE: Header Tank Question - 6/8/2008 6:00:54 AM
freeair
Status: online
this may be or may not be any different but when i used to race model powerboats i had a 67 size outboard engine fitted with a 2 oz header tank set level with the carbs venturi and the main 10 oz tank was down lower about 3 inches, the engine never failed . i think the inverted flight could be a different story . if you have room to fit a very small header tank in the engine bay and keep your main tank at the correct level this would work fine.
(in reply to On The Patch!)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.532RCU1
