build light
NE, USA Status: offline
quote:
ORIGINAL: Demon-Leather quote:
ORIGINAL: flying poodle Those plans look great! I think my next project will be a small glider like the imperial, only powered by a 0.20 pee wee. I may even try to cover in tissue for the first time. ehhhh,.... use Solite.. It's a LOT easier, shiney & bright, AND lighter. By the time you buy the dope, thinner,Brushes or spray equipment, and good tissue... it's actually cheaper! It's also easier to patch. Growing up,. I HATED doping tissue. That's what gravitated me to all-sheet designs. You could clear dope them, add a color trim or two, and be DONE with it! The absolute cheapest I've found Solite commercially is here: http://www.aeromicro.com/Catalog/solarfilm_lite__solite__2398707.htm If you find it anywhere cheaper..PLEASE, let me know. They have free shipping on orders over $100.00 US. I just wait till I need everything, or expen$ive batteries, motors, or something till it totals over a hundred bucks ..& order. Solite doesn't shrink as violently as Monokote or other high-temp coverings. is low-heat foam safe (look at the "Foamin'20" ) And is cheaper than paint or dope...AND, is totally fuel-proof. Bob Bob! Good to see you poking your head out again. That is still expensive as coverings go.Ever used Doculam? One third the weight of Monokote and so much cheaper than $kote you would squeal for joy like a lttile schoolgirl out of control!!! Fuelproof and you can paint it on the inside for a glass like shine or on the outside for less shine and drab or flat colors. I would be glad to send you a sample of some to try. (You have been good to me in the past!) I gots more than plenty!!! Robert P.S.If you paint it on the outside you should scuff the surface real good with steel wool or a good wet or dry paper P.S.S. Do you have plans for the Scientific Models Parachute Plane??? 40 inch span Rubber model.
< Message edited by build light -- 6/28/2008 6:28:24 AM >
_____________________________
Keep'er light, and she will treat you right!
