Ntc3 ?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> Ntc3 ?
Page: [1]
Login
Ntc3 ? - 6/8/2008 8:51:54 PM
onebdgti
Status: offline
Hey guys just found this forum and all I can say is how usefull it is. Now down to the ? I have a Team Associated NTC3 and the front wheels aren't turning when I run the car. When I hold it in the air with the car off and spin the wheels all of them spin. But when I hold one of the front wheels the main drive shaft quits spinning.. I've pulled the rear diff out and everything looks good. Could this be the cause of a poor adjusted diff?
       Post #: 1
RE: Ntc3 ? - 6/8/2008 8:55:30 PM
Osirisf16
Status: offline
Maybe your center differentail's oil is too thin. Or maybe you should check your front diff what's going on. And check if everything is in its place as it should be
_____________________________
Kyosho Evolva M3 - OS VZR / Kyosho MP777 SP1 - OS Vspec / Hyper 8 - OS Vspec / Baja 5b
I CAN FLY, WHAT EVER THAT MEANS.
(in reply to onebdgti)
       Post #: 2
RE: Ntc3 ? - 6/9/2008 12:17:10 AM
GYNAIKAS
Status: offline
Does NTC3 have a blocked front diff?
I simply love perfection...do something as good as you can or don't do it at all...
(in reply to Osirisf16)
       Post #: 3
RE: Ntc3 ? - 6/9/2008 1:51:11 AM
scottywilkes
Status: offline
no, the factory team kit comes with a locker diff, but the standard RTR is a normal ball diff front and rear.
Seeing its the front diff thats not turning have u removed that? Sounds like u may of stripped a pinion gear
Other reasons could be a stripped out wheel hex, all the power would go to the stripped wheel, not giving the wheels drive.
Also a CVD could be broken at the joint, there are many things
MGT;Mach 427, FT NTC3;RBC12, RTR NTC3, Tamiya F103, NEVST, RC18T, Jato;STS28
(in reply to GYNAIKAS)
       Post #: 4
RE: Ntc3 ? - 6/9/2008 3:17:42 AM
onebdgti
Status: offline
Nope the front diff is fine. What was wrong with it was the rear diff was too loose and not transfering the power to the front driveshaft. After I tightened up the rewar diff it works fine now.
(in reply to scottywilkes)
       Post #: 5
RE: Ntc3 ? - 6/9/2008 7:30:10 PM
GYNAIKAS
Status: offline
Are the final gears ok?
       Post #: 6
RE: Ntc3 ? - 6/9/2008 10:18:54 PM
onebdgti
Status: offline
Yeap all the final gears were fine.
       Post #: 7
RE: Ntc3 ? - 6/10/2008 12:14:29 AM
trini4life
Status: offline
hmm. i may have a answer to this. there is a pin behind the wheel hub adapter. make sure that it is there.
       Post #: 8
RE: Ntc3 ? - 6/12/2008 8:43:00 PM
onebdgti
Status: offline
Yeap its still there. I've already checked that out cause when I noticed that the main drve shaft wasn't turning when a load was put on it that was the first thing that I checked. But it seems that I have fixed the problem when I adjusted the rear diff. I'm assuming that the preveous owner luved to drift the car so he loosened it up. Now that I tightened it back up the front is turning now under a load.
(in reply to trini4life)
       Post #: 9
RE: Ntc3 ? - 6/12/2008 9:05:25 PM
Doonagoowin
Status: offline
If you drift, you lock the differential not loosen it
       Post #: 10
RE: Ntc3 ? - 6/14/2008 2:53:05 AM
onebdgti
Status: offline
Didn't know that you tightened it to make it drift. But since the front wheels are working now the thing handles 10x better. Now I just have to find some better tires.
(in reply to Doonagoowin)
       Post #: 11
RE: Ntc3 ? - 6/14/2008 3:17:12 AM
onebdgti
Status: offline
I was wondering what do people do to these cars to make them handle better? Put sway bars on them or do they put a one way diff in it. Any help would be great cause I.m not new to the R/C hobby just new to on road cars. The only thing that I have messed with are my RC10's and my T-Maxx's.
       Post #: 12
RE: Ntc3 ? - 6/14/2008 8:10:27 AM
j8to33
Status: offline
quote:
ORIGINAL: onebdgti
I don't have my ntc3 yet but I have a jato and the swey bars don't do anything. But I don't know about it on the ntc3.
Jato 3.3 with spektrum dx3, JD carbon turnbuckles, all rpm, trx cdv's, chrome low-mid resonator, aluminum shockbodys, + more
       Post #: 13
RE: Ntc3 ? - 6/14/2008 2:52:33 PM
Igotntc3andrevo
Status: offline
Hey onebdgti
I have a nitro tc3 thats pretty decked out and a few things help it control better if you play with the diffs to get them right that is one way but putting a solid diff in it i do not think would help you we normally put the solid diff in the tc3 if we are trying to have both wheels spinning equally at the same time ie. drag racing but if you want the best handling characteristics then definitely stick with the diffs. you can change to foam tires given that the area you run is pretty smooth with few rocks (imho the best upgrade).
another thing to check is that all the adjustments such as camber, toe, akermen, are all adjusted correctly. setting up the suspension and if you have the rtr getting the aluminum shocks with the threaded ajdusters would be great. You should also purchase the factory team spring set from AE and test out the different spring weights to your liking. other than that there isnt much for you to do because for its time the Ntc3 was the best handling shaft car out.
wish i was a millionaire
(in reply to j8to33)
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
