Help with batterie(s) Blade CX
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> E-Flite Helicopters >> Help with batterie(s) Blade CX
Page: [1]
Login
Help with batterie(s) Blade CX - 6/9/2008 12:18:59 AM
chriskim95
Status: offline
Help!! My batteries are not in balance. I use my batteries for about 5 minutes until they are just above the low voltage cutoff. I wanted to check my balance of my batteries. One of them was 7.4 and the other was 3.89 I balanced them out useing eat2muchrice's tutorial. Once I balanced them both out to 3.89, I plugged them into my stock e-flite charger. When they were done charging, they were 7.4 and 3.89 after flying AGAIN!! Ive tried this with both of my batteries. Is my charger bad?
       Post #: 1
RE: Help with batterie(s) Blade CX - 6/9/2008 1:42:33 AM
Crusader23
Status: offline
You need to recheck which wires you're checking your voltage for. 7.4 sounds like the total voltage and 3.89 is one of the cell's voltage. Double check to make sure you're checking the correct cell voltage.
_____________________________
4 more months and I''ll be home
(in reply to chriskim95)
       Post #: 2
RE: Help with batterie(s) Blade CX - 6/9/2008 1:55:52 AM
chriskim95
Status: offline
i checked the red black and the red blue... is that the right ones?
(in reply to Crusader23)
       Post #: 3
RE: Help with batterie(s) Blade CX - 6/9/2008 7:56:39 AM
eat2muchrice
Status: offline
NO! you tested the wrong wires. Crusader is right, recheck your wires.
There are three wires that go into the charger plug. What you should get is three different readings with your voltameter.
red=left, blue=mid, black=right
To check each cell
Cell 1 red+blue=4.2v
Cell 2 blue+black=4.2v
Note: red+black = The total amount of voltage in both cells 8.4v.
Here is the link again. Look very closely at the pictures.
Eat2muchrice’s Cheap Battery Test and Fix
http://www.rcuniverse.com/forum/m_6970199/tm.htm
Good luck.
<<--- My dogs first look and sniff at her worst nightmare.
       Post #: 4
RE: Help with batterie(s) Blade CX - 6/9/2008 4:43:00 PM
ArrowNaughtic
Status: offline
At 7.4V total and the first cell only reading 3.89V that leaves the second cell with a voltage of 3.51V. That is NOT in balance and is off by a larger margin than what most consider to be a balanced set of cells. Readings for both fresh off the charger should be closer to the 4.2V per cell and not at 3.8V and 3.5V.
Please check them as soon as you finish charging them and let us know the readings of both cells and total voltage. I am hoping you will be showing a 4.2V per cell and a 8.4V for the total of the pack. eat2muchs tutorial is spot on and should help you determine if the charger is the culprit or just the way your heli draws from the cells. Five minutes is at the low end of flight times for the stock lipos and could be a warning sign of something else happening in your heli. (motors, servos, ect) I only get 5 minutes out of mine but I am also running LED's on my CX2, without them I get the full 8 - 10 minutes of flight.
_____________________________________________________________________________________
Of all the things I ever lost....................................... I miss my mind the most!
(in reply to eat2muchrice)
       Post #: 5
RE: Help with batterie(s) Blade CX - 6/9/2008 10:59:24 PM
chriskim95
Status: offline
whats the in margin of balancing my lipos?? Im at about 3.80 and 3.84... is that close enough?
(in reply to ArrowNaughtic)
       Post #: 6
RE: Help with batterie(s) Blade CX - 6/10/2008 6:29:43 AM
eat2muchrice
Status: offline
quote:
ORIGINAL: chriskim95
That will hurt your flying time by alot. On a full charge they should read at 4.2v each.
       Post #: 7
RE: Help with batterie(s) Blade CX - 7/16/2008 7:03:31 PM
chriskim95
Status: offline
wow this charger is wierd, Oh well, I'm getting a TP1010C with a TP-205V from a friend for 50 bucks.... Yeah, the flight times suck, I wish I had better flight times. I currently have a HeliMax charger and am wondering if I can just balance the li-pos and charge them from the JST connectors...
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.859RCU1
