robart or century jet retracts which are better?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Scale Aircraft >> robart or century jet retracts which are better?
Page: [1]
Login
robart or century jet retracts which are better? - 6/9/2008 3:09:09 AM
corey_09@hotmail.com
Status: offline
I would like to know one people experince if robart or century jet makes a better retract?
please give me any input you may have.
       Post #: 1
RE: robart or century jet retracts which are better? - 6/9/2008 3:20:42 AM
pahtreek
Status: offline
I think Robart makes a superior product. The only exception is the .60 model rotating retracts for the P-40 or Corsair or Hellcat. I went thru 3 sets of rotating robart retracts, and the century jet's seemed to hold up better. The wierd thing is, when you get into the larger warbirds (80"-110" wingspan), like a Ziroli plane, the Robarts are 10x the gear of the Century Jet.
I had Century Jet custom make some gear for my Ziroli P-40, and they got sent back 3 times with problems, and I only had 10 landings, and I greased every one in. It has been a few years since I bought them ,but the two weak parts are the air cylinders are just a pressed fit for the o ring which easily fails, and the side walls for the gear mounts is way too soft aluminum. They also use crappy weak aluminum rivets to hold the sissors on the oleo strut together (replace them
with 4-40 bolts if you buy them).
Just my two cents worth.
www.putfile.com/pahtreek
< Message edited by pahtreek -- 6/9/2008 3:21:03 AM >
_____________________________
"Now YOU listen to me Bobby Boucher! ARF's are da-devil !"
But mama, I LOVE them! They make me feel good.
(in reply to corey_09@hotmail.com)
       Post #: 2
RE: robart or century jet retracts which are better? - 6/9/2008 3:41:08 AM
warks62
Status: offline
I agree with Pahtreek that has been my experiance also.
Randy, member of the true 1/6th Royal Corsair Build
(in reply to pahtreek)
       Post #: 3
RE: robart or century jet retracts which are better? - 6/9/2008 6:13:48 AM
Wayne22
Status: offline
I have 2 sets of CJ for 60 size warbirds....both are loose and sloopy...one set has not even flown yet! Robarts have proven to be much better, but there are even better ones out there if you are willing to pay the $$ for them..
All I ask is for a chance to prove that money can't make me happy......
(in reply to warks62)
       Post #: 4
RE: robart or century jet retracts which are better? - 6/9/2008 10:36:34 AM
pahtreek
Status: offline
Wayne,
Are your .60 size robarts the rotating ones, or just a straight retract like on a P-51 or P-47? I have only had this experience with the rotating ones like on a P-40 or Corsair.
Yea, I think everyone out there agrees that Sierra Precision (just google it) makes the strongest, best designed gear available. Just have to fork up the $$$$.
< Message edited by pahtreek -- 6/9/2008 10:41:40 AM >
(in reply to Wayne22)
       Post #: 5
RE: robart or century jet retracts which are better? - 6/9/2008 6:01:58 PM
Wayne22
Status: offline
one set is for the top flite p-51, the other for the top flite Spitfire..both straight non rotating retracts....
Ditton on Sierra Precision!
       Post #: 6
RE: robart or century jet retracts which are better? - 6/9/2008 10:44:20 PM
Status: offline
thanks im buy a set of retracts for the top flight 1:7 scale 62in winspan. so are the robarts or century jets more robust because i would like a reliable long lasting set of retracts.
thanks
       Post #: 7
RE: robart or century jet retracts which are better? - 6/10/2008 12:24:58 AM
pahtreek
Status: offline
What plane are you buying them for? P-51, P-40 etc...
       Post #: 8
RE: robart or century jet retracts which are better? - 6/10/2008 3:32:31 AM
Status: offline
top flight 1:7 scale p-51 mustang
       Post #: 9
RE: robart or century jet retracts which are better? - 6/10/2008 4:57:27 AM
warks62
Status: offline
quote:
ORIGINAL: corey_09@hotmail.com
Corey my favorite is the Robart 550RS which are 90 degree or the 551RS which are 85 degree. The reason is they are strong, don't have a lot of play in them, and most important with any retract is you can install the strut directly in the retract. No wires to grind flat spots in or bend. Toe is set very easy just slide the strut into the retract set your toe and tighten the pinch bolt. This is the best setup for the money in my opinion. Or another option is the spring down version but same idea I put a link to both. The spring down only accept 3/8" struts but the 550 will accept a 3/8" or 7/16" strut now you just have to choose what you need. But I believe your plane takes a 90 degree retract I know the kit built one did.
http://www.robart.com/retracts/8-18lb550.aspx
http://www.robart.com/retracts/6-12lb510.aspx
       Post #: 10
RE: robart or century jet retracts which are better? - 6/10/2008 3:05:56 PM
Steve Collins
Status: offline
With the exception already mentioned above, Robarts are superior in every way to the Century Jet retracts. That includes the air valves and all the other support equipment.
Sierra is Top Dog when it comes to retracts!
Steve Collins
       Post #: 11
RE: robart or century jet retracts which are better? - 6/17/2008 12:27:57 AM
flynavy
Status: offline
I just peeked in on this thread to see what was being said. I myself have played around with all types of lg. both manufactured and home grown types. From my own experience, I,ll go where you get what you pay for. Robarts hqave never I repeat NEVER failed to do their job even with my trying to fix the things that aren't broke!!! Ihave seen a site however that has got my attention and thought I,d pass it on It's called euro kit. This is an outfit in italy that has a distribution center in chicago they make all types of struts wheels and landing gear. The volume and variety looks pretty good and the retracts are offered in mechanical, hydraulic, and pneumatic versions. They also have a line of electric ,and pneumatic/hydraulic brakes. I just thought I'd pass it along and if anyone has had experience with them please pass it on. happy landings!!
(in reply to Steve Collins)
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
