jeffs555
Zflyer, The Helihobby instructions assume you are using a rate gyro. With a Heading Hold gyro, you wire it like the Helihobby instructions, but ignore the part about setting up revo mix. A HH gyro doesn't need, and won't work with any transmitter mixing enabled. If you try flying it with revo mixing on, the heli will never stop spinning. Are you practicing on PreFlight with a "time factor" of 1 or less? The "time factor" changes with the scenario, and the training scenario defaults to a "time factor" of 3, which means it runs 3 times slower than normal. You check and set the time factor with "Quick Edit" under the "Scene" menu. If you already knew this and are flying the MD500E MicroElectric at a time factor of 1 or less, you should have no trouble with the HB. The MD500E under PF flys a lot like the HB. Jeff
