AndyW
Joined: 1/17/2003 From: Timmins, ON, CANADA Status: offline
Thanks to Greg, I ventured to have a look at JD's starter fluid MSDS. I found the company that provides the fluid to John Deere. Company Technical Chemical Company Technical Chemical Company/TCC Contact Name Glori Wilcoxon City Cleburne State / Province Texas Country United States Phone (800) 527-0885 x Email gwilcoxon@technicalchemical.com Web http://www.technicalchemical.com A toll free number is provided so I called. Glori listened with amusement to my query but she understood fully what we were doing. According to her, the fluid they provide JD is, by percentage, 83.59 % ether .68 % oil 9.7 % propane/butane blend 6% carbon dioxide. She explained that the C02 evaporates virtually instantly no matter what method you use to evacuate the can. However, the butane/propane blend will stay in solution for some time, especially if you freeze the can. I take an 8 ounce jar and punch a small hole in the lid. Then I replace the original spray button with one that uses a tube, I think that's from WD40. Just spray into the jar through the hole in the lid and that guarantees that virtually all of the other 20% is evaporated off. She confirmed that this was a good strategy. Meanwhile the MSDS lists the main ingredient as 1,1-Oxybisethane. So I asked her about that. Well, even she was taken aback a bit but after a few minutes on hold she told me that the number under that word, 60-29-7 is the CAS number. This is a number assigned to every chemical that lists all the names given to a particular chemical. So I looked it up. Here, http://www.jtbaker.com/msds/englishhtml/E2340.htm We find, 1. Product Identification Synonyms: Ether; ether,anhydrous; Diethyl ether; 1,1'Oxybisethane;ethyl oxide; diethyl oxide; Ethyl ether anhydrous; CAS No.: 60-29-7 Molecular Weight: 74.12 Chemical Formula: C2H5OC2H5 Product Codes: J.T. Baker: 9238, 9244, 9246, 9248, 9250 Mallinckrodt: 0848 Further, she advised that the best site for information on chemistry is, www.chemfinder.com So I looked up ether and got this, http://chemfinder.cambridgesoft.com/result.asp Greg is right. Not doing a thorough job in your research and then passing off mis-information doesn't take us to where we want to be. Thanks Greg.
_____________________________
Andy Woitowicz
