Katana Freestyle 40 / 81 Tops
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> Katana Freestyle 40 / 81 Tops
Page: [1]
Login
Katana Freestyle 40 / 81 Tops - 6/10/2008 9:07:49 AM
freeair
Status: offline
i finally gave my new Katana 40 and run today and i tell you guys that this model is the ducks nuts so to speak, absolutely spot on.
thanks to a few guys on this forum who suggested the correct c.o.g. from the stated 99 mm to a correct 140 mm this model is a gem to fly, i have fitted an OS 81 F Stroke which is no where near run in as yet but the grunt this engine has with this particular model is great, i only flew this with low rates set as i thought this is the way to go at first secound flights just to get used to this models caractoristics ect . take off within 30 feet not a problem [ on grass ] to hover it was at around 1/3 rd throttle and abit more it was going vertical until i had to drop out of the 500 meter limit. landing was like landing a trainer tail drager as soon as the front wheels where just about on the ground i applied a very little amount of up elevator for a perfect 3 point landing, [ 4 flights / landings ] this model has,nt seen nothing yet as its not fully run in plus its running a 14 x 6 master airscrew prop and the control rates are flat. i intend to gradually increase control rates until i get to the max, as for power if any of you guys have this model or are thinking of buying one [ katana / funtana ] same thing i would definetly go with an 80 sized 4 stroke and not a simular 2 stroke for this type of flying model , or should i say hovering 3D model. thanks again guys for your support.
       Post #: 1
RE: Katana Freestyle 40 / 81 Tops - 6/10/2008 11:28:54 PM
Gregor32
Status: online
i have been flying this (esm katana 40) for about a year now and love it, i had to look on the uk forums to find out about the rearward cog, i have a mag 70 on mine with fast digital servos on rudder and elevator , i can hover at just over half throttle, this is a very forgiving airframe, your os81 should be awsome when its run in, i havent found any bad habits with this plane i have about 45deg travel on all surfaces. loctite your landing gear mounting bolts, mine came loose and i lost a boltand had to land with the gear at 45deg and it damaged the cowl, enjoy and dont be scared to throw it around. Greg
Click to see fullsize image.
Click for fullsize
(in reply to freeair)
       Post #: 2
RE: Katana Freestyle 40 / 81 Tops - 6/11/2008 6:19:46 AM
freeair
Status: offline
quote:
ORIGINAL: Gregor32
Greg, your model is identical to mine. i am running Spectrum DS-821 servos with a J.R. 1100mah 4.8 v rx pack and i must say these servos are very quick and provide plenty of torque, they would be awsome on 6 volts. also i did some mod work to the undercarriage base so now i have an extra alloy plate fitted with 4 bolts instead of the stock 2.
(in reply to Gregor32)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.672RCU1
