rcjon
GA, USA Status: offline
quote:
ORIGINAL: HeliWill Hey guys, My titan and I are going backwards inverted now. The trouble is with my Gy401. It acts normal for about 3/4 of a turn then, "the gyro gets stuck." I have to add more and more rudder commad to keep the tail coming around and then it catches up and swings like crazy. Before I would get into a overcontroling nightmare, now I'm anticipating the "Stuckingness" and can keep it going, but its still ugly. Any suggestions? P.S. the same thing happens with regular backwards at fast speeds. Thanks I had a similar problem with a 401 in forward flight, and in pyros. See the thread "Weird Tail Behavior". And when I would roll the heli, the tail would just flip over about halfway through the roll, making things interesting. Piros were slow-fast-slow-fast-slow-freeze - then they would be fine. For 6 months I bugged people about it and they all wanted to blame set-up, tail blades, head bogging, belt, pilot, and everything you could possibly think of. I checked and rechecked everything, while at the same time I'm flying the crap out of my other Raptor with a GY401 and no such problems. I finally bought a new GY401 and after it was installed all my problems went away. Since you are obviously farther down the learning curve than I am (doing backwards inverted) , the solution to your problem may not be the gyro, but don't ignore the possibilty that it just might not be functioning properly.
_____________________________
Time spent doing something you enjoy is never wasted.
