aland25
FL, USA Status: offline
If your going to do all of this, the only change I would recommend to what Druss said is to spend the money on the metal gear cyclic servos. The HS65MG's can withstand quite a few crashes (and you will crash). Better to pay the money now than have to buy multiple HB servos. Also, on the lipos, correct me if I am wrong, but the higher the C rating, the less of the chance you take on "puffing" the battery. It will also run cooler as well. I an running the Kong Powers as mentioned above and love them. I also run the Extreme 2200 25C batteries from Helidirect.com. They run about $60 each
