Gyro and 3º fuel tank for F16 1-9 Skymaster
Tower Hobbies
Logged in as Guest
  Printable Version
The JETLEGEND L-39 (3 COLOR SCHEMES) We now offer building & Special Paint scheme
Seller:  FlyingboyD
Details:   $2,600.00   |  8/16/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Gyro and 3º fuel tank for F16 1-9 Skymaster
Page: [1]
Login
Gyro and 3º fuel tank for F16 1-9 Skymaster - 6/10/2008 10:51:29 PM
machI
Status: offline
Hello Everyone
I'm new on the jets, and need help on these 2 questions for my skymaster F16 (1-9) with a jet cat P60 on the tail.
1 - To increase the time flight, I need to instal the 3 fuel tank on the bypass area (on top of both fuel tanks). Can you inform the brand an ref. for the best fuel tank?
2 - I heard some imputs about gyros. For this model who is the best gyro. Some times during the landing with cross wind, the wings of the plane are not stable.
Its correct to instal a gyro on the ailerons?
Regards
Helder
       Post #: 1
RE: Gyro and 3º fuel tank for F16 1-9 Skymaster - 6/11/2008 12:10:44 AM
twax4real
Status: offline
1. With a P-60 the 2 saddle tanks are plenty of fuel. You will get close to 10 minute flights just with the stock tanks.
2. Gyro's are for the steering. never heard of someone putting one on ailerons.
(in reply to machI)
       Post #: 2
RE: Gyro and 3º fuel tank for F16 1-9 Skymaster - 6/11/2008 2:50:33 AM
CPS
Status: offline
Hi,Helder:
In our RC club,many experience about the Skymater 1/8 F-16 can share with you.It is very stable and most time needn't Gyro.However,if you use it,the F-16 can fly more gentle.(I use one two-axial GYA352 gyro because I use tailron to control it,the alieron was fixed) The recommended C.G position on the web site of Skymater is too foreward,it will result the F-16 too nose-heavy and a little"spin" sensation when you turn.We adjust the C.G to about 14-15cm backward of joint of leading edge of wing,this "spin"condition will imporve.The steering don't need Gyro,it is very stable.
The 3rd fuel tank is recommended by Skymaster web site to reduce the bubble aspiration by pump.Most bubbles formed in the
main saddle fuel tanks will remain in the 3rd fuel tank,little will captured by UAT.Therefore,one small 3rd fuel tank is enough.(about 200 to 300 cc)
The F-16 is very suitable to beginner of jet and I hope you can enjoy it!
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to machI)
       Post #: 3
RE: Gyro and 3º fuel tank for F16 1-9 Skymaster - 6/11/2008 6:19:28 AM
Rider-60
Status: offline
Hello Helder,
Ask mikedenilin here on RCU, he has a specially made conformal tank for the F16, I have a standard flat Sullivan 16oz on mine http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXFT72&P=SM
the best airplane gyro seems to be from ACT, http://www.acteurope.de/html/fuzzypro_smm.html.
Cheers
Florent
(in reply to CPS)
       Post #: 4
RE: Gyro and 3º fuel tank for F16 1-9 Skymaster - 6/11/2008 11:13:18 PM
machI
Status: offline
CPS, thanks for your reply.
Nice photos. In fact i have already the UAT, and I will add one more on the top of both fuel tanks (5 or 6 minutes is not enought for fun).
My F16 CG is 145mm and flies very well.
Just a photo of my F16. Is not the best but i will post more soon.
regards
Helder
Click for fullsize
(in reply to Rider-60)
       Post #: 5
RE: Gyro and 3º fuel tank for F16 1-9 Skymaster - 6/12/2008 12:14:33 AM
machI
Status: offline
Hello rider-60
Thanks for your imput. i will install that fuel tank. Mean time i will contact ACT for more informations.
The gyro manual is on Germany language and i must have one in english to learn more.
regards
Helder
(in reply to machI)
       Post #: 6
RE: Gyro and 3º fuel tank for F16 1-9 Skymaster - 6/12/2008 1:52:42 AM
jetnuno
Status: offline
Hi Helder,
A gyro will greatly improve airborne stability, spaecially in windy conditions.
You can try both the Futaba GY351 or the ACT Fuzzy Pro. Other brands are possible as long as thet have dual inputs for 2 servos and no Hold mode is necessary or wanted in ailerons.
Your Tiger is realy a ****cat
Nuno
(in reply to machI)
       Post #: 7
RE: Gyro and 3º fuel tank for F16 1-9 Skymaster - 6/12/2008 7:21:12 AM
Rider-60
Status: offline
Hi Helder,
The instructions are also in english, just scroll down the page http://www.acteurope.de/intanlfuzzySMM.pdf
(in reply to jetnuno)
       Post #: 8
RE: Gyro and 3º fuel tank for F16 1-9 Skymaster - 7/15/2008 8:46:57 PM
larry baraniuk
Status: offline
I just bought a skymaster f16 and plan on using the fuzzy pro smm to assist in take offs and landings.
I'm hoping to get nice landing characteristics with this setup.
I've been trying to find some videos of any jets using the fuzzy gyro assist for landings but haven't had any luck.
I'd love to see a landing that looks nice and gentle with the nose wheel taking its time touching down.
I really think that fuzzy gyro setup would help in achieving that.
I am a taileron flier and I hate thinking of loosing one of my taileron fins during flight (and it has happened)
I think that having the fuzzy smm controlled ailerons would be a safety feature for taileron controlled planes.
Larry
< Message edited by larry baraniuk -- 7/16/2008 6:33:10 AM >
       Post #: 9
RE: Gyro and 3º fuel tank for F16 1-9 Skymaster - 7/16/2008 11:16:36 PM
jetnuno
Status: offline
Hi Larry
You either use the gyro on aileron axis or elevator axis. You can use gyros on both axis, only with 2 gyros. Both have to have dual plugs for servos.
I make this comment because of your 4th paragraph.
Fuzzy is nice. Sure will help you.
Sorry, but the videos I have there is no info regarding gyros.
(in reply to larry baraniuk)
       Post #: 10
RE: Gyro and 3º fuel tank for F16 1-9 Skymaster - 7/22/2008 8:46:50 PM
larry baraniuk
Status: offline
I guess what I'm trying to achieve is trying to land the F16 using allot of "Aerobraking" The following showtread video shows a classical example of extreme areobraking at the end of the video www.rcgroups.com/forums/showthread.php?p=8434253&highlight=aerobraking#post8434253
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
