willey
PA, USA Status: offline
Tom, Not sure what you are using, but the low end primers will clog the sand paper very easily, if you do alot or plan to do a nice paint job it's "worth the money" "and the time" to invest in an activated automotive primer (2 part), little more hassel to mix and clean the spray gun (definitely clean the gun within the hour or two or it will harden in the gun). NOT GOOD! that's kinda like the don't touch the stove it's HOT! story, it happens once and you won't forget!! Laquer primers shrink so stay away from that when you can. By "TIME" I mean the time it takes "to" sand, sands very easy and won't shrink on you overtime like low end primers, that means less primer used also. Sand paper - get some 3M black 213Q wetordry paper, with this paper and a good primer it will not clog comes in all grits & you can buy it by the sheet (again - automotive paint store) I use 180 (sometimes), 240, 380, 500, 800, 1200 dry - then wet sand with 1500 then go to paint. the primer I think you can get it in quarts too. Hope this helps, just my experience
_____________________________
++HUN HUNTER++
