Joined: 10/16/2002 From: Indianapolis, IN, USA Status: offline
Just purchased a Tower Hobbies Fun 51 kit. Nice little kit although looks a bit on the small side to me. I have been wanting a twin for fun flying and to have something a bit different. Also a bit of a break in the scale building department. Has anyone taken one of these profile kits and converted it into a twin? It has a 44" span and only 32" in fuse length. I am considering a 60" span 40" fuse length and using two .46size engines I just happen to have. Looks like a simple conversion and could be a lot of fun in the flying department.
NC, USA Status: offline
I haven't done this mustang but have bashed a few twins. If yo uadd a 12" center section that would be good. The Fun 51 is a bit short so it would be nice to lengthen the fuses and 40" is about right. The only real thing I dissapree on is the .46 motors, I think they will be too much. The Fun 51 is a slow fly plane and the twin would probably be happiest on .35 to .40... I understand there is a throttle and you could prop down to a 12X5 to use the .46's...
_____________________________
Revver #125, Pico Owners Club #3 R/C Anonymous. My name is Evan and I have not flown for 14 hours.
I agree on the fuse length and wingspan. I plan on adding 8" to each tip for a total wingspan of 60". The OS LA46 motor is an entry level power plant and very light given it has bushings. It would certainly be very easy to over speed this plane.
FL, USA Status: offline
I looked into doing a P-82 Twin Mustang out of 2 Fun 51 kits, but never got around to it. The 82 was really a different plane, even though it looks like Mustang at first glance.
The 51 kit has a span of 45" and an area of 630. Extending it to 62" will give an area of 886 sq in. The fuselage length goes from 34.5" to 44.3"
Visual differences are: 1. The top of the nose on the 82 is a straight line, where the Mustang is curved. 2. The canopy on the 82 is forward of the Mustang. 3. The air scoop on the 82 is further forward. 4. The 82 is longer. 5. The 82 has a taller tail like the P-51H. 6. The 82 tail wheel is further back.
I was planning to use 2 OS .46AXs. I have a twin fuselage version of the Sonic 25 with 2 OS .46LAs and the AXs will be better. I would also recommend a flap in the center.
If you drop me an e-mail, I'll send you some better 3-views. These are gifs and they don't publish very well.
< Message edited by Ed_Moorman -- 6/13/2008 12:01:08 AM >
Ed Moorman, AMA 553, KD4QBM, Revver Bro #156 R/C Report Magazine, Fun Aerobatics Column
I have decided to build this fun fly into a fun 82 or F82? Hmm! If there is interest I will do a building thread. Never done one before from start to finish, or "finished" in this case if it won't fly! Hollar if you want to see a build thread, enough hollern' and I will give it a shot. Maybe shot is a poor choice of words?
Well I did decide to build or bash this kit(s) to make a stand way off P82. Here is a bare bones picture before I start to cover. Outer wing panels plug in.
GA, USA Status: online
Ha, ok. What engines are you using? Are you doing anything with the control surface area between the fuses, like a flap? And how are you doing the elevator control?
I love originals.
When someone loses a plane in the pits, you do a lomcevak duck. Press Alt F4 to see my other witty line.
I am using OS .46 LA's. Flap located between fuse's, the elevator and rudder servos mount in the bottom of the main wing along with the flap servo, reciver and battery and switch harness. I have found a grey nyrod to run down the inside of the fuse halfs. Rudder on one side and elevator on the other. I will use a drag ling between the rudders. Outer wing panels plug in and contain a servo in each for the aileron control. Each motor has a Hitec HS81 servo for throttle control and a six ounce fuel tank. The radio is a JR Spectrum DX7 using a total of 7 servos.
I just have the radio install to do yet and then it will be ready to break in the motors. Hope I will be ready to fly yet this year, as other projects are taking more of my time.
.46's will be way too much power for this plane, in my opinion. Two .25's are hot hot on my Dazzler Arf, that I bashed. It's much faster than my single engine Dazzler with a .70 4S, and my buddies Dazzler with a hot .46 2S.
Be sure to detune the aileron throws from what you are use to on your similarly sized singles. The prop wash over them make them much more responsive/ effective.
Good Luck!
Johnny C!
"...and once man has tasted flight, he will walk the earth with his eyes turned skyward... L. DaVinci.
