To foam or not to foam!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Seaplanes >> To foam or not to foam!
Page: [1]
Login
To foam or not to foam! - 6/12/2008 5:34:28 PM
captjckirk
Status: offline
I have a chance to get a set of Sig hollow glass floats at a very reasonal price, the ones that came with the non-fuel proof paint. I can re-paintno prablem, my question is-is there any reason to fill them with foam, the kind that comes in a can?
       Post #: 1
RE: To foam or not to foam! - 6/12/2008 6:36:42 PM
evan-RCU
Status: offline
Don't. The pressure of the foam expanding can burst the floats and if you get water in them the foam doesn't let you get it out.
_____________________________
Revver #125, Pico Owners Club #3
R/C Anonymous. My name is Evan and I have not flown for 14 hours.
(in reply to captjckirk)
       Post #: 2
RE: To foam or not to foam! - 6/12/2008 7:53:13 PM
captjckirk
Status: offline
Thanks, will use as is.
(in reply to evan-RCU)
       Post #: 3
RE: To foam or not to foam! - 6/15/2008 7:03:52 PM
JimCasey
Status: offline
I built a RC boat for my son once and foamed the inside. The foam swelled enough to cause noticeable distortion of the hull, but did not split it.
There are now "low expansion" versions of the canned foam.
Still, I agree with Evan. Those floats are robust enough and the foam will only add weight. Just be sure you cknow how to fab a drain plug if they ever leak.
Jim Casey/Seaplane Nerd
http://www.smilesandwags.com/Floats.html
       Post #: 4
RE: To foam or not to foam! - 6/16/2008 3:15:54 PM
captjckirk
Status: offline
Hi Jim, thanks for your in-put. Any suggestions on installing a drain plug would be welcome. Joe
(in reply to JimCasey)
       Post #: 5
RE: To foam or not to foam! - 6/19/2008 12:59:02 AM
JimCasey
Status: offline
One I have seen that worked well:
silver-Solder a #10-24 nut to a washer. Figure out where that will fit and drain best, and drill a 1/4" hole in the center of that area. Epoxy the nut/washer assembly centered over the hole. Then plug the hole in the nut with a small 10-24 machine screw and a rubber gasket.
       Post #: 6
RE: To foam or not to foam! - 6/19/2008 4:02:20 AM
evan-RCU
Status: offline
Drill a small hole in the top of the float and simply put some RTV over it. If you get water in the float peel it off drain then put RTV back over it.
       Post #: 7
RE: To foam or not to foam! - 6/19/2008 11:01:00 AM
Fast Guy
Status: offline
I just bought a couple drain plugs from an Aquacraft boat, drilled a couple holes and installed them.
Drain Plug
Drive to Stay Alive!!!!!
       Post #: 8
RE: To foam or not to foam! - 6/26/2008 1:50:58 AM
fairplane
Status: offline
Hey-I have a set of great planes fiberglass floats and I was going to fill them with foam as they have a tendancy to crack. Once the water is in the wood soaks it up and they get heavy too- has anyone tried foam with success? I thought if I layered it in slow and in several steps this would work and I thought that should keep the water out? These floats seem to get a crack just about every time they are in the water.
(in reply to Fast Guy)
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.578RCU1
