Trouble with PVC tires
Tower Hobbies
Logged in as Guest
  Printable Version
Team Losi Muggy - RTR
Seller:  PastorVee
Details:   $1,100.00   |  10/10/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Drifting >> Trouble with PVC tires
Page: [1]
Login
Trouble with PVC tires - 6/13/2008 1:23:03 AM
NitroMMt
Status: offline
So I am new to drifting and have an HPI Nirto RS4 3 with PVC Tires. If I give the car any considerable throttle it jus spins in circles, I cant drive in a straight line and steer in any direction without it spinning out. Any ideas of what is wrong? I know its going to be touchy but this isnt drivable. Thanks for the help.
       Post #: 1
RE: Trouble with PVC tires - 6/13/2008 2:01:29 AM
Doonagoowin
Status: offline
It's nitro. Go with ABS because PVC is very fine and will not give you any grip at all.
ABS will at least give you a little grip that will let you move forward.
Besides, you don't need considerable throttle to drift. With my RS4 I use 1/4 throttle max.
(in reply to NitroMMt)
       Post #: 2
RE: Trouble with PVC tires - 6/13/2008 2:07:48 AM
TIGER76
Status: offline
Practice throttle control m8
Practice pulling away slow in a straight line forward first to see how much throttle u need on pvc its slippy as hell but once u get the throttle right then you can start sweeping out into drifts etc.
Trust that pulling away trick taught me how to drift when i first used pvc
And once the pvc wears in a bit and the shine has gone they give a bit more grip not loads tho
_____________________________
VXL pede/ 9.6v 4600 mAh & 8.4v 4500mAh (x2)
TT-01r / Quake ESC / Trinity D6 9Turn / Orion Rocket Pack 4500 (X2)
(in reply to Doonagoowin)
       Post #: 3
RE: Trouble with PVC tires - 6/13/2008 3:10:29 AM
DriftingDragon
Status: offline
you only go even half throttle when your heading for a corner then start braking and turning then slight throttle and practise alot
maybe try backing off your throttle trim or put it to the 30/70
| DF-03 | E-Firestorm | Desert Truck | TT01 RX7 | Tamiya highlift |
(in reply to TIGER76)
       Post #: 4
RE: Trouble with PVC tires - 6/13/2008 2:57:06 PM
NitroMMt
Status: offline
Thanks guys! I will be trying the tips out tonight, and keep practicing
(in reply to DriftingDragon)
       Post #: 5
RE: Trouble with PVC tires - 6/14/2008 1:26:48 AM
magnat
Status: offline
The Idea is not to gun the throttle on PVC tyres...
Ideally, there best suited to electrics rather then a nitro
You shouldn't need any more then a split second pulse to kick the tail out...
Remember, RC Drifting isn't about speed, its about controlling the slide...
Traction: What a drag.....
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.500RCU1
