Brand New GST 7.7 Won't Start
Tower Hobbies
Logged in as Guest
  Printable Version
Team Losi Muggy - RTR
Seller:  PastorVee
Details:   $1,100.00   |  10/10/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> CEN Racing >> Brand New GST 7.7 Won't Start
Page: [1]
Login
Brand New GST 7.7 Won't Start - 6/13/2008 6:48:48 AM
runangolee
Status: offline
I just got my 7.7 today and cannot get it started no matter what I do. I am using O'Donnel 20% RTR fuel. I have checked and double checked and triple checked the glow plug. I've changed to a different glow plug. I even installed my Ofna primer pump to see if that would help.
I've now gone through 1/3 of a tank just trying to get it started and 4 of my fingers are missing skin.
This truck is BRAND NEW. What could possibly be the problem??
       Post #: 1
RE: Brand New GST 7.7 Won't Start - 6/13/2008 1:03:08 PM
sparky 25
Status: offline
Try the idle set screw as i had real bother starting mine first time until i opened the idle,
If you set the carb about 1mm from fully closed it should cure the problem,
I also went through half a tank and a lot of blisters until i took a look at the idle set screw
hope you get it sorted let us know if this works
These pics should help
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by sparky 25 -- 6/13/2008 3:29:41 PM >
(in reply to runangolee)
       Post #: 2
RE: Brand New GST 7.7 Won't Start - 6/13/2008 2:44:52 PM
nomobux
Status: online
quote:
ORIGINAL: runangolee
Fuel, spark, compression. Your fingers tell me you have compression ( wear a glove ). A 3rd of a tank tells me if you've never gotten started, you are flooding it. Does it even POP ? Check the base settings, pull the plug and clear the motor.
_____________________________
" I GOTTS NOMOBUX "
       Post #: 3
RE: Brand New GST 7.7 Won't Start - 6/13/2008 2:50:22 PM
The Real Dogman
Status: offline
He needs to tune for the Checkvalve, he is flooding it right now!! Remove the Valve and break it in without the valve, then reinstall the valve then tune for it. Have not tested break-in with valve in place, but I'm sure it can be done, just need to lean the needles enough to get it started but rich enough to break it in well..
Hope this helps, but if you need more help I will be here..
My Wife Knows How Much It Really Costs And Still Loves(lets)Me!
Nemesis/Genesis/Matrix Arena/Wheely King Tuber/Axial Co
(in reply to nomobux)
       Post #: 4
RE: Brand New GST 7.7 Won't Start - 6/13/2008 3:31:07 PM
nomobux
Status: online
quote:
ORIGINAL: The Real Dogman
Your right .. I missed that he had already put the valve on ... my bad.
" I GOTTS NOMOBUX "
(in reply to The Real Dogman)
       Post #: 5
RE: Brand New GST 7.7 Won't Start - 6/13/2008 6:13:15 PM
Status: offline
good job guys- very helpful...
If you are still having trouble please contact us at customerservice@cenracing.com
Best Regards
CEN Racing - www.cenracing.com
       Post #: 6
RE: Brand New GST 7.7 Won't Start - 6/13/2008 10:33:59 PM
runangolee
Status: offline
Thanks for all the replies!
I took it to my friend who is an RC pro and WE GOT IT RUNNING!
We took the check valve off first, as Dogman suggested, but still couldn't get it running and it was still crazy rich. I checked the LSN and it was a full 2 turns out from flush so we leaned that out, then leaned out the HSN, gave it more idle, and a fully charged glow starter. After just a few turns she came to life!
It seemed to be set much too rich from the factory, and I think my glow starter was too weak.
I'm breaking it in now with the heat-cycle method. Unfortunately after getting it running I found my front brakes didn't work at all. I'm not sure if it fell off or if it was never put on but the front brake lever and spring were completely missing. I looked for any loose screws when I got it but its hard not to miss something.
Thanks again for the help, I can't wait to start tuning!
(in reply to CEN Racing)
       Post #: 7
RE: Brand New GST 7.7 Won't Start - 6/13/2008 10:40:29 PM
Status: offline
Sounds like you need mx203 and gs276- just to let you know some of our factory guys run rear brake only as it makes the truck turn better on the race track!
Best Regards
       Post #: 8
RE: Brand New GST 7.7 Won't Start - 6/13/2008 11:04:13 PM
burningpoo
Status: offline
I had to crack my plug a little to get it to start at first, then tighten once the glow starter was off. I know I'm late, and it's running, but might help someone else.
Taking unbroken toys aparts since 1981
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.547RCU1
