foodstick
Once upon a time there was a great hobbyshop named Marbles Hobby Supply..It was located on the south east side of Des Moines in a mostly undeveloped area. It was up on a hill along some rolling woods, next to some train tracks, then river bottom area down below ... (which is flooded now ) .. Anyhow, a few years before I started flying some daredevil had his big new glow motor break a motor mount and go zooming off to who knows where... Now I know those guys never let it lay long without rounding up a search party.. but it was a sly motor and covered its tracks well. years go by, and everytime someone went out in the woods, you would hear the tale of the one that got away... "Keep an eye out for that motor" you would hear as you trudged over the knoll. I think most of us had started to think of the story as a folk tale, a lesson hard learned about building your planes correct.. maybe even an alien abdution gone wrong ,ha ha Even extended searchs where a guy and his girlfriend might spend an hour looking for what seemed an easy recovery....that motor went undiscovered...Nobody ever thought to bring in a MOTOR-WHISPERER, or build some experimental motor devining rod...possibly a crime psychic would have been of use if she would have laid hands on the other half of the motor mount still attached to the plane ? All I know is when someone walks hunched over for hours ....and says "Thats a right odd looking mushroom" The case had been solved! It was sitting proudly on the case at the Main hobby shop in Urbandale ( Hobby Haven ) last time I heard.. cooling fins corroded nearly solid, and froze up solid ( who'd a thought! ) I wonder if it was down on the ground the whole time, or maybe hung in the top of a tree for awhile..just to enjoy the air and view... The old cruddy plastic prop looks like you could pull it off and it would work just as bad now as when it was new.... I'm not going to do it though..maybe it was the prop that flew away..and just took the motor with it...
