Solved my problem, with airboat tilt insted of slide
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Boats >> RC Airboats >> Solved my problem, with airboat tilt insted of slide
Page: [1]
Login
Solved my problem, with airboat tilt insted of slide - 6/14/2008 9:31:54 PM
kokker
Status: offline
i found that the with of the boat and the style of the rudder ha a lot to say.
now i just have one problem left to solve. please if any one have a solution to this or an idea say so
at high speed my boats seams to wanna leev the whater.
i have tryed the following, to place some waight in the front(i am now of that belive that all the waight shouldt be in the back, correct me if i am wrong... )
make spoilers ditten seem to work.
i have made Servo ajustabal spoilers ditten seem to have any efect.
i can maby poast a video later whan i am finished with the modification. for now here is some pics.
i know it looks orful at the moment. but i will sand it wown and repaint it...
       Post #: 1
RE: Solved my problem, with airboat tilt insted of slide - 6/14/2008 9:37:36 PM
kokker
Status: offline
oh i forgot the boat where
50cm x 25cm (15cm at the bottom)
now it is
50cm x 30cm (20cm at the bottom)
(in reply to kokker)
       Post #: 2
RE: Solved my problem, with airboat tilt insted of slide - 7/16/2008 1:24:34 PM
kokker
Status: offline
Update
i wil soon post more pics,
I think i will put a bigger Brushless engien on it,
but i have run in to problem, i have coeted the buttom with filler and Gellcoate
only problem is i ditten put enough hardner in so it as dryed now for 6 days, and the surfic is stil sticy,
anyone have an idea on how to get it to harden ?
       Post #: 3
RE: Solved my problem, with airboat tilt insted of slide - 7/16/2008 9:28:34 PM
sportygreg
Status: offline
I had the same problem when I coated a hull with resin that didn't have enough hardener.Put it in the sun or use a hair dryer-the heat will help greatly.
_____________________________
I hope I'm in heaven a half hour before the devil knows I'm dead!
       Post #: 4
RE: Solved my problem, with airboat tilt insted of slide - 7/16/2008 9:56:08 PM
cracker39
Status: offline
Sometimes applying more epoxy with a little extra hardener works as the hardener will leach into the first coat and cure it. You just have to work fast with a "hot" batch before it sets up.
Dale
(in reply to sportygreg)
       Post #: 5
RE: Solved my problem, with airboat tilt insted of slide - 7/17/2008 9:45:49 PM
kokker
Status: offline
i think it is getting there it just take for ever
i have tryed baking it infront the Fireplace in safe distens ofcourse
when i get it sanded down i will post pics of it
(in reply to cracker39)
       Post #: 6
RE: Solved my problem, with airboat tilt insted of slide - 7/17/2008 10:19:30 PM
kokker
Status: offline
Gellcoate not sanded yet
new top finish
What do you think.... it will make the world of diff when it gets paintet
       Post #: 7
RE: Solved my problem, with airboat tilt insted of slide - 7/18/2008 4:30:04 AM
crispyspa
Status: offline
Nice job on the mod. I can't wait to see it finished.
"Are you alright, son? I keep hearing the most terrifying sounds in there." (Foghorn Leghorn)
       Post #: 8
RE: Solved my problem, with airboat tilt insted of slide - 7/18/2008 9:50:59 AM
kokker
Status: offline
tanks man, it is the 3 time i makes mobs to this boat, hopfuly tis time i get i right
i am still looking for the rright engien for it the one that is on at the moment is only for markup
(in reply to crispyspa)
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.469RCU1
