Newbie needs help with TT-01:)
Tower Hobbies
Logged in as Guest
  Printable Version
OFNA Jammin CRT.5 - ARR
Seller:  jessemxt
Details:   $300.00   |  8/31/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Drifting >> Newbie needs help with TT-01:)
Page: [1]
Login
Newbie needs help with TT-01:) - 6/15/2008 7:47:09 PM
Goral
Status: offline
Hi
I am completly newbie in r/c cars . I have just bought stock Tamiya TT-01. What I have to change? I want to have a good drift car for good amateur or semi-professional. I think first thing what should be changed is engine??Please give me advice. Thanks
       Post #: 1
RE: Newbie needs help with TT-01:) - 6/15/2008 7:49:40 PM
car man
Status: offline
ball bearings and drift tires made from abs, alloy drive shaft, the stock motor will work, and that should be it
(in reply to Goral)
       Post #: 2
RE: Newbie needs help with TT-01:) - 6/16/2008 1:30:52 AM
peetiewonder
Status: offline
my tt01 setup
gtb/7.5r 19t pinion 61t spur
ball bearings
aluminum shaft and motor mount
ball bearing steering
cf upper deck
sways (blue)
trf dampers with tamiya yellow springs
aluminum 3racing dogbones
rear spool, front ball diff
adjustable upper arms and front links
so i have about 300 dollars in parts not including motor and servo in mine, but it drifts like a dream
_____________________________
A wise man once told me dont argue with fools,
Because people from a distance cant tell who is who.
(in reply to car man)
       Post #: 3
RE: Newbie needs help with TT-01:) - 6/17/2008 8:03:36 PM
Goral
Status: offline
Hello
I need an advice with the part for my r/c car
Which shocks should i pick??
http://cgi.ebay.co.uk/GPM-Alloy-Threaded-Damper-Shocks-50mm-TT-01-tt01-TT01_W0QQitemZ310054259150QQihZ021QQcategoryZ34063QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
http://cgi.ebay.com/GPM-Alloy-Complete-Damper-Shock-SET-B-fits-TAMIYA-TT-01_W0QQitemZ180253082537QQihZ008QQcategoryZ34061QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.co.uk/Oil-Shock-Damper-4-Tamiya-TRF-HPI-1-10-1-10-Touring-Car_W0QQitemZ120150995837QQihZ002QQcategoryZ140979QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
http://cgi.ebay.com/X-Spede-Tamiya-TT01-55-60mm-Shock-Set-Blue_W0QQitemZ160251106173QQihZ006QQcategoryZ19167QQrdZ1QQssPageNameZWD4VQQcmdZViewItemQQ_trksidZp1638Q2em124
ENGINE:
Tuned 540:
http://TAMIYA-Mabuchi-RS540-Sport-Tuned-Modify-Black-Motor-23T_W0QQitemZ160248882812QQihZ006QQcategoryZ34061QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
Lightly tuned 28T
http://cgi.ebay.com/53983-TAMIYA-1-10-R-C-LIGHTLY-TUNED-motor-28T_W0QQitemZ130163449463QQihZ003QQcategoryZ34061QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
SuperStock:
http://cgi.ebay.com/Tamiya-Super-Stock-Motor-RZ-53697_W0QQitemZ380036536673QQihZ025QQcategoryZ44028QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
Super Stock RR:
http://cgi.ebay.com/49260-Tamiya-Super-Stock-Motor-Type-RR_W0QQitemZ260221433279QQihZ016QQcategoryZ34061QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
or last one Acto tunef M- special
http://cgi.ebay.com/Tamiya-53251-ACTO-TUNED-M-SPECIAL-Race-Motor-M02-M03-04_W0QQitemZ190224224231QQihZ009QQcategoryZ34061QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
Can some of you tell me exacly what parts you have? I mean ball bearings, sways, rear spool, front ball diff etc.
I have one more question is it TT-01 Chassis???
http://www.putfile.com/pic/8310266
Thank you for help. Cheers;]
(in reply to peetiewonder)
       Post #: 4
RE: Newbie needs help with TT-01:) - 6/27/2008 9:16:01 PM
DANDthekid
Status: offline
I would suggest is to modify the tires, get rid of those rubber tires way to much grip. So go to your hardware store, picking up some ABS Plastic Piping (bring a rim, for sizing)
(not PVC, because if you use PVC there is very little traction and you will just be messing up more than learning, and ABS has the perfect balance)
Swap out those tires, and practice. Then build up from there.
Don't try to learn on a "non beginner drift car"
Please read this it will answer some of your questions!
The Beginners Guide to Drifting!
http://www.rcuniverse.com/forum/m_6327870/anchors_6327870/mpage_1/key_/anchor/tm.htm#6327870
I learn on spray paint caps!
< Message edited by DANDthekid -- 6/27/2008 9:18:44 PM >
The closest thing to drifting is drifting RC. The next closest thing, is drifting around Homedepot with a shopping cart.
(in reply to Goral)
       Post #: 5
RE: Newbie needs help with TT-01:) - 6/28/2008 1:12:23 AM
Captain Nemo12
Status: offline
Quick question, I see the TT-01 Type E ball bearings as listed separately on RCmart... does anyone know if they will fit the standard TT-01 chassis?
In the works: HL Panzer III, Type VIIb U-boat
(in reply to DANDthekid)
       Post #: 6
RE: Newbie needs help with TT-01:) - 6/30/2008 8:10:46 PM
peetiewonder
Status: offline
yeah the e bearing set will fit u will just have a couple bearings left over because the e has bearings in the steering.
(in reply to Captain Nemo12)
       Post #: 7
RE: Newbie needs help with TT-01:) - 7/1/2008 4:05:44 AM
magnat
Status: offline
Goral: To get a TT-01 sliding..
I would Suggest a Tamiya RZ motor, a 15T Reversible ESC and do the Ball Bearing and alloy propshaft upgrade with a Change to some Hard Compound tyres..
I learned on PVC Tyres, then Swapped to ABS once I had the car control worked out.. Learning on the Slipperiest Compound possible may take longer but your car control will be more advanced then if you went straight for the Easiest compound...
< Message edited by magnat -- 7/1/2008 4:06:20 AM >
Traction: What a drag.....
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.267RCU1
