lemmerjo
ON, CANADA Status: offline
Empty Wallet, You are probably going to want it in idle up to do loops, or 3D. In normal, you might be able to pull up on the stick and give it full power, but in idle up, you have the negative pitch and throttle when you bring your throttle stick down, so therefore, you can go inverted and not be pulled towards the ground. I was out again for two more flights with the T-Rex last night, and Im loving it! Im starting to hover inverted, but I am experiencing some blade cavitation I think it is. When I flip it over, the blades dont bite the air like in a hover, it takes a bit of playing with the throttle to get it to bite in. This also happens when upright. It seems when I come out of forward flight into a hover, I lose grip of the air with my blades for a few seconds. Any thoughts? Thanks Joe
