dacaur
UT, USA Status: offline
quote:
ORIGINAL: rmoetken Well, not so sure if one of these are up yet, I've only noticed a mlst but, here's a new one if there is! By the way, any using an aluminuim spur with the stock pinions? Is that a good combo to do or use both alum spur and pinion? you dont want metal on metal in the spur/pinion area, as it will wear quickly unless the gears are hardened, which being aluminum they arent.. aluminum is too soft... stick with plastic spurs and just set the mesh and slipper right and they will last a long time.
