Axe EZ connections
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Helimax >> Axe EZ connections
Page: [1]
Login
Axe EZ connections - 6/16/2008 5:10:07 PM
Inconel_601
Status: offline
I've got a second hand Axe EZ that I plan on using with a Futaba 8U transmitter in PPM mode.
Can someone tell me what the connections on the electronics board go to?
Right now, I've got the rear motor (upper rotor) to the lower connector and the front motor (lower rotor) to the upper connector (next to the battery). Is this correct?
Which servo goes to which connector? Can't remember how I connected the servos, but does only one servo move at a time? For example, when I move the RH stick forward, only one servo moves. Shouldn't both servos move to tilt the whole swashplate forward like in a CP heli? I actually used v-tail mixing on the 8U to make it move like it normally does in a CP heli.
Any help would be appreciated. Thanks.
       Post #: 1
RE: Axe EZ connections - 6/16/2008 6:51:46 PM
nla_pes
Status: offline
The front or forward motor is wired to the top set of pins.
The rear or motor is below it.
The top three pins is for the right/and left yaw servo.
The last three pins is the up and down servo.
Also make sure your rotors are spinning at the same speed.
Regards,
Paul
(in reply to Inconel_601)
       Post #: 2
RE: Axe EZ connections - 6/17/2008 3:47:41 AM
RWT
Status: online
In regards to the servos. That is not the same control system as the CP. They move individually.
If your flight times are short the motors are probably junk. Restating, in my experience the motors are junk and don't last long.
RT
       Post #: 3
RE: Axe EZ connections - 6/18/2008 12:49:10 PM
Inconel_601
Status: offline
I got the motors correct.
Now, which servo (left or right?) on the heli goes to the top servo pins on the RX?
And, which servo (left or right?) on the heli goes to the bottom servo pins on the RX?
(in reply to RWT)
       Post #: 4
RE: Axe EZ connections - 6/18/2008 1:25:35 PM
nla_pes
Status: offline
View the attached Photo it should help. I have only included half the callouts but you should be able to figure out the rest. You can see I have marked each connectorer. Hope this helps.
Regards,
Paul
Click to see fullsize image.
Click for fullsize
       Post #: 5
RE: Axe EZ connections - 6/18/2008 1:30:47 PM
nla_pes
Status: offline
Sorry the previous picture was too large I am posting another.
Paul
       Post #: 6
RE: Axe EZ connections - 6/18/2008 1:46:23 PM
nla_pes
Status: offline
Here goes another try
Click for fullsize
       Post #: 7
RE: Axe EZ connections - 6/19/2008 12:48:08 PM
Inconel_601
Status: offline
Picture didn't load. Can you try again? Thanks.
(in reply to nla_pes)
       Post #: 8
RE: Axe EZ connections - 6/19/2008 1:36:20 PM
nla_pes
Status: offline
Lets try this again.
Paul
Click for fullsize
       Post #: 9
RE: Axe EZ connections - 6/19/2008 1:39:32 PM
nla_pes
Status: offline
I have contacted thne Admin. to find out why my picture will not load.
Paul
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.734RCU1
