RE: KMP Corsair    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Scale Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  5/1/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: KMP Corsair
Page: <<   < prev  46 47 48 49 50 51 52 53 [54] 55   next >   >>
Login
RE: KMP Corsair - 10/2/2012 2:38 PM
glazier808
Score: 291
Last Login: 5/18/2013
Status: offline
Nooooo!
Oh well, most of my memories of him being a bad influence on me as too.
RIP Captain Morgan
Casey
_____________________________
Fliteskin, Sierra, Nelson Hobby, MICKO aircraft, Getstencils, Holman Plans, VicRC, Castle Creations, Addicted to Luft
Hide Signatures
(in reply to Rate1)
       Post #: 1326
RE: KMP Corsair - 11/23/2012 8:08 PM
predman
Score: 100
Last Login: 5/19/2013
Status: offline
Finished mine with a RCGF 26cc up front, plenty of power. I did not add any right thrust at all and it flies perfect.
Hide Signatures
(in reply to glazier808)
       Post #: 1327
RE: KMP Corsair - 12/9/2012 7:24 PM
tevans55
Score: 123
Status: offline
I just finished my ESM Corsair. It has a DLE 35 and Sierra retracts with an Earl Aune tail wheel. I changed the paint scheme slightly using Porter Paint exterior latex. I installed a Tys cockpit. The pilot is a Aces of Iron bust and a Century Jet bottom to create a full pilot. I put two 3000 mAh nicads under the cowl for weight and they are a dual setup throught a Smartfly Batshare. Also used a Tech-Aero Ultra BEC to run the ignition off the receiver batteries.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Nothing difficult is ever easy.
Spitfire Brotherhood #44
Hide Signatures
(in reply to predman)
       Post #: 1328
RE: KMP Corsair - 12/10/2012 4:55 AM
Flight 21
Score: 100
Last Login: 5/3/2013
Status: offline
Beautiful! That's just about exactly how I hope to build one someday. Very nice plane.
"Do or do not. There is no try." -Yoda
Hide Signatures
(in reply to tevans55)
       Post #: 1329
RE: KMP Corsair - 12/10/2012 5:09 PM
tevans55
Score: 123
Status: offline
Thanks, Flight21
This is my fourth ESM/KMP plane. I really enjoy their planes. They are not exactly ARFs and they leave a lot of room for innovating in your own ideas (and the ones I copy from others here on RCU).
Hide Signatures
(in reply to Flight 21)
       Post #: 1330
RE: KMP Corsair - 12/30/2012 6:41 PM
tevans55
Score: 123
Status: offline
Winter project almost done now with weathering.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1331
RE: KMP Corsair - 1/1/2013 4:41 PM
skillet92
Score: 117
Status: offline
 Tevens55 I have the same tail wheel and love mine. Have you flown yours yet? I have not flown mine yet and used a G-38 converted to EI for power.  Seems like enough.  How much did yours come out weighing and where have you balanced yours.
Michael.M Waco brother #187
Hide Signatures
       Post #: 1332
RE: KMP Corsair - 1/1/2013 7:27 PM
tevans55
Score: 123
Status: offline
I have not flown it yet as I am still doing some engine adjustments and vibration testing. Mine weighs 18.75 lbs. and I believe I balanced it at either 4.25 or 4.5 inches. Weather here is a little cold and damp...will probably wait till Spring for maiden flight.
Hide Signatures
(in reply to skillet92)
       Post #: 1333
RE: KMP Corsair - 1/1/2013 8:24 PM
Prekin
Score: 101
Status: offline
Hi all,
here is a picture, which you can use as a sticker on your car. If you want, you can print it.
Click for fullsize
Hide Signatures
       Post #: 1334
RE: KMP Corsair - 1/2/2013 3:21 PM
skillet92
Score: 117
Status: offline
 Thank you.  Mine came in around 19.3 and is balanced right at 4 1/2.  My first was balanced there but I had no retractable tailwheel.  It came in in the 18.5 range.  Flew like a baby.  I lost it when the engines ignition crapped out and locked out the radio.  Had plenty of power with the G-38 turning a 18x8 xoar.  With about half flaps it just floated in.  Just like you I am waiting to get some good weather to maiden this one.  Love the look of the corsair.  I have an ESM P-51 with a dle 30 and have an ESM FW-190 on the bench for a winter project.  Good luck on your maiden.
Hide Signatures
(in reply to Prekin)
       Post #: 1335
RE: KMP Corsair - 1/2/2013 3:55 PM
drifter
Score: 115
Status: offline
http://www.youtube.com/watch?v=bpniAwQB_OU&feature=youtu.be
Video of second flight with an OS 1.60 and Sierra gear.
Why do they call it "dead weight" if it keeps your airplane alive?
Hide Signatures
       Post #: 1336
RE: KMP Corsair - 1/2/2013 11:34 PM
tevans55
Score: 123
Status: offline
Drifter-
You did not seem to use much flap. Was there a reason for that?
Hide Signatures
(in reply to drifter)
       Post #: 1337
RE: KMP Corsair - 1/2/2013 11:39 PM
tevans55
Score: 123
Status: offline
quote:
ORIGINAL: skillet92
I was thinking of maybe doing the ESM P-51B next. Is it a good flyer? I also have the Spitfire which I have really enjoyed and the B-25 which only has one flight so far.
SPitfire
http://youtu.be/xpTW87KRNzc
Click for fullsize
Hide Signatures
       Post #: 1338
RE: KMP Corsair - 1/3/2013 3:58 PM
drifter
Score: 115
Status: offline
quote:
ORIGINAL: tevans55
Drifter-
Just nerves, and not paying attention to where the flap lever was.
The little I used added lift but no braking. The plane didn't want to settle in.
At 16.5 lbs with over two lbs of lead on the firewall flaps were still not a necessity , but look really good deployed on final.
Hide Signatures
       Post #: 1339
RE: KMP Corsair - 1/3/2013 4:57 PM
skillet92
Score: 117
Status: offline
 Drifter.  My first one I used about half flaps to get it to brake.  Now mine was about 2 pounds heavier than yours.  So that could be some of your flap tendencies.  Looks like plenty of power.
Hide Signatures
       Post #: 1340
RE: KMP Corsair - 1/3/2013 9:54 PM
tevans55
Score: 123
Status: offline
With the Earl Aune tail wheel/tail hook I could see it was going to take a lot of nose weight so I put 2 3000mAh NiCds in the cowl. You can see one of them in the photos above. It still required some additional lead to balance.
Hide Signatures
       Post #: 1341
RE: KMP Corsair - 1/9/2013 8:54 PM
Rate1
Score: 100
Last Login: 5/15/2013
Status: offline
Tevans55, drifter,
Nice. Pictures like these certainly will motivate me to start thinking about getting back into the build.
<--- This is my dog, Capt Morgan, and he has propably more flight hours than you.
Hide Signatures
       Post #: 1342
RE: KMP Corsair - 1/19/2013 11:33 AM
Rate1
Score: 100
Status: offline
tevans55,
Your main gear door does not look like mine, looking at the lower part, seams like it's connected to the gear strut?
Nice work with the weathering. Can you go through how you achived that excellent look, what material, paint, tools you used.
Hide Signatures
(in reply to Rate1)
       Post #: 1343
RE: KMP Corsair - 1/20/2013 3:29 AM
tevans55
Score: 123
Status: offline
Rate1-
Thanks for the compliments. Ihave been trying to improve my weathering with each plane. Most of what I am trying are suggestions I have been picking up on the web and talking to guys at scale competitions.
You are correct that I have attached the front gear door to the bottom of the strut. The first thing I did was to throw out the doors that came in the kit and make smaller doors that were the proper size. I attached the top of the door to the wing with a DuBro flat nylon hinge. At the base of the door I attached a 1/16 brass tube horizontally using V Poxy for strength. Then I just ran a very small wire through the tube and around the strut. This allows the strut to rotate and slide easily moving the door with the strut. I hope that makes sense...if not, let me know and I will take a picture.
The weathering started with oil based pastels. I started with white light gray and black. I rub the pastels on sandpaper and with a very small, thin brush start to brush mixtures of these three colors into the rivets and panel lines on the fuselage. I wanted to keep the colors light because this plane was being flown from sandy runways in the Pacific which would leave a faded dusty residue on the planes from the research I could get my hands on. The wings have no panel lines or rivets so my goal was to lightly simulate some of the lines. What I did was to use blue masking tape to create the lines. What I did was put a piece of tape where I wanted a line and then brush light gray pastel along the edge of the tape. Then I would pull up the tape and lightly rub the line with the edge of some DuBro foam rubber (cut into a wedge). Rubbing it out softens the edges and makes the surface look a little more worn. I have been practicing with this for a couple of years after watching Dave Johnson put pastels on his Albatros right before judging at the Scale Masters and the Nats. The oil based pastels stick much better and hold up really well. They can also be easily reapplied.
The next thing I did was cut about a 1/2" ball of 0000 steel wool and clamp it in a set of hemostats. I then poured a small spot of "steel" Model Masters paint on a piece of paper and rubbed the steel wool in the paint. Then I dabbed it on a dry spot on the paper to wipe most of the paint off and began lightly blotting the leading edges on the plane where I wanted chip marks. Don't rub it on just dab it on. I also did the same thing on the wing where pilots and mechanics walk on the wing (next to the fuselage). I also cut 2 small anti-skid foot steps for the wings from black silicone sandpaper. I think it was the wet/dry #600 paper.
Next I started with the air brush using flat black to highlight the machine gun residue on the wings and the scale looking exhaust I made on the bottom of the fuselage. I also lightly streaked the wings and fuselage along leading edges but only in a few places. I then air brushed some light brown over a little of the black exhaust on the under side. Next I found a color I really like to create that light, grimey look. It's made by Vallejo for air brushes called German Grey - 71.052. I really gives that faded look on the fuse and wings and dulls down the steel color nicely. I very lightly streak the wings and fuse and this also helps seal and dull the pastels.
Then I took the smallest brush I could find and went around some of the edges of panel lines, rivets, hatches and canopy with steel paint. I just painted small spots here and there to make them looked worn and scratched. A little goes a long way with everything.
Each plane I am learning to do less and less. I hope this helps a little. Good Luck with your build.
Tim
Hide Signatures
(in reply to Rate1)
       Post #: 1344
RE: KMP Corsair - 1/20/2013 7:13 PM
Rate1
Score: 100
Status: offline
tevans55,
Nice responce. I belive I understand how you made the gear doors. The way you are discribing it you make it sound so easy and straight forward. Did you use ply or fiberglass for these doors? What thickness of the material? I have som Q10, fiberglass laminate, 1mm thick I could use.
Same thing with the weathering, you make it sound so easy. In my mind you have produced something artistic. I belive that I might have to start practice on these skills at some point if I want to learn it myself and it might as well be on this aircraft. Wich by the way is my first scale and warbird.
However, I'm struggeling to find the time to sit down and build as my hope is to have this plane ready at spring.
I do like what you have done to your plane and I'll be delighted if I could even reach half way of your result.
Thank you for sharing your techniques as these are valuble to me.
Christian
Hide Signatures
       Post #: 1345
RE: KMP Corsair - 1/20/2013 7:24 PM
tevans55
Score: 123
Status: offline
The 1 mm fiberglass will work great. I used plywood only because I had scrap the right size. Another thought would be to cut down the door that comes with the kit. Q10 would be my first choice for durabilty. I know you can do what I have done to mine...it's not very difficult. Just takes a few evenings with some music on the radio and you'll done in no time. The other nice thing is the pastels you can do over and over till it looks the way you want. I also use pastels on the pilot after the paint has dried. Great for shading and making things look a little used and dirty. Good Luck and post photos as you go.
Hide Signatures
(in reply to Rate1)
       Post #: 1346
RE: KMP Corsair - 1/20/2013 7:27 PM
Rate1
Score: 100
Status: offline
Do you seal the weathering with clear coat when you are satisfied?
I have been searching for a decent looking pilot but failed. Any hint where to look?
Hide Signatures
       Post #: 1347
RE: KMP Corsair - 1/20/2013 7:38 PM
tevans55
Score: 123
Status: offline
No it is very durable the way it is. Even flat clear coat it will give a sheen...you want it to look naturally grimey. The paint overspray with German Grey seals the pastels as well as necesary. You can also reapply anything that may be damaged and you can also use these techniques to cover up future hangar rash. I also purchased paint from Home Depot in the dark blue and gray to paint the plane with where the light blue was. I can now use that paint for touch up of future damage. (I'm really good at scraping the wing tip bottoms when I turn.)
My pilot is an Aces of Iron top attached to a Century Jet bottom. I had to modify the bottom to fit right but the bottom gave my pilot arms which the Aces of Iron pilots don't have. Another fun little project! here is a photo of the beginning project.
Click for fullsize
Hide Signatures
(in reply to Rate1)
       Post #: 1348
RE: KMP Corsair - 1/20/2013 7:41 PM
Rate1
Score: 100
Status: offline
Oh, you are not alone being good at that.
Hide Signatures
       Post #: 1349
RE: KMP Corsair - 1/20/2013 7:43 PM
Rate1
Score: 100
Status: offline
Although I'm scraping my plane to and from the car.
Hide Signatures
(in reply to Rate1)
       Post #: 1350
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.375RCU1
