RE: E-flite Hawker Sea Fury 400 ARF
Tower Hobbies
Logged in as Guest
Users viewing this topic: doug.jeff
  Printable Version
All Forums >> Electric Aircraft Universe >> Park Flyers & Backyard Flyers >> RE: E-flite Hawker Sea Fury 400 ARF
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: E-flite Hawker Sea Fury 400 ARF - 7/5/2008 9:32:21 AM
zzz12
Status: offline
Thanks will look at the servos to see if i can stop the buzzing. Cut the arms down
(in reply to doug.jeff)
       Post #: 26
RE: E-flite Hawker Sea Fury 400 ARF - 7/5/2008 6:33:04 PM
doug.jeff
Status: online
Here is another link to my Sea Fury.
Sea Fury
(in reply to zzz12)
       Post #: 27
RE: E-flite Hawker Sea Fury 400 ARF - 7/9/2008 2:50:58 PM
zzz12
Status: offline
Blow a servo on the landing gear . Going put the fixed landing on for now . Can not get it to work with out buzzing .... Crap landed gear on this plane....Thanks for you help
       Post #: 28
RE: E-flite Hawker Sea Fury 400 ARF - 7/10/2008 3:36:19 AM
doug.jeff
Status: online
Sorry to hear that. If interested here is another video of mine flying.
Sea Fury
(in reply to zzz12)
       Post #: 29
RE: E-flite Hawker Sea Fury 400 ARF - 7/11/2008 1:44:45 PM
zzz12
Status: offline
Good video . Waiting to take her up weather here is wet and wind for now. Hope she flys ok................................Thanks
       Post #: 30
RE: E-flite Hawker Sea Fury 400 ARF - 7/13/2008 5:51:52 PM
zzz12
Status: offline
Help plz took the sea fury up to day .I put full power on her and she jumped around the sky and dropped a wing . Park 480 power. Went to 50% power and flys ok looks like it can not take full power of the park 480 help plz
(in reply to zzz12)
       Post #: 31
RE: E-flite Hawker Sea Fury 400 ARF - 7/13/2008 9:10:05 PM
David Eichstedt
Status: offline
quote:
ORIGINAL: zzz12
Can you describe a little more about what you mean by "jumping around the sky and dropping a wing?" Is it possible you were getting glitches?
I've looked back in the thread and seen your setup, and I do have a few comments.
First, are you still trying to use the ParkZone 1800 mAh LiPo? The Park 480, 1020kV is rated at 28A burst current. The 1800 pack is a 15C battery, so it should be able to do 27A continuous. However, if you've done any damage to the pack in the past, perhaps by running it in a model until you hit low voltage cutoff, it might not be able to put out what you're asking from it any more. You could be getting enough voltage drop at full throttle that the ESC isn't able to feed the receiver the voltage it needs, hence spotty rf performance shown by glitches. Maybe you should try a more-capable battery.
Second, what's the history on your ParkZone receiver? Did you crash the model it was originally in? Have you done a range check with the Sea Fury both power on and power off?
Third, it could be you're getting electromagnetic interference (EMI) of some kind that only shows up at full throttle. EMI can be weird, showing up when you don't expect it. Again, range checking both power-off and power-on is important, especially in this situation.
Last weekend I built a Sea Fury for myself (my personal fleet) with a Park 480 and I got to maiden it during the week. I hadn't flown one since last September when I was in China, so I had forgotten how well it flies. Locked-in feel, very fast and aerobatic, smooth and fun. But I flew it using a ParkZone 2200 pack with an unknown history, and when I landed the pack was a little on the soft side. It looked OK after it cooled down a little (it never got hot, just slightly warm) and I wasn't afraid to charge it, which went OK, but I'm not going to fly that pack again in the Sea Fury.
David Eichstedt
Horizon Hobby
_____________________________
David Eichstedt, Horizon Hobby
Director of Aircraft Development - Hangar 9, E-flite, ParkZone, HobbyZone, etc.
(in reply to zzz12)
       Post #: 32
RE: E-flite Hawker Sea Fury 400 ARF - 7/14/2008 12:27:04 AM
doug.jeff
Status: online
Sounds alot like radio glitches. My Sea Fury flies straight as an arrow no matter what position or throttle it is at. Try a range check with the model on the ground at full power make sure all control surfaces stay rock solid always a good idea with a new model no matter how reliable the reciever has been in previous models.
Jeff
(in reply to David Eichstedt)
       Post #: 33
RE: E-flite Hawker Sea Fury 400 ARF - 7/15/2008 12:31:11 AM
zzz12
Status: offline
Thanks for your help when she is flying at full power it turns and drop down hard . Take the power to 50-60% flying well . Will check the plane out on the ground with full power on. If it is glitches how would you stop it
       Post #: 34
RE: E-flite Hawker Sea Fury 400 ARF - 7/15/2008 5:28:13 AM
doug.jeff
Status: online
If it glitches check the routing of the antenna make sure it is not ran next to any power wires. Also read Davids post. Was the reciever in a crash? If so that could be the problem. Receiver may look good but being electronics maybe a cold solder joint broke. Also the part about the battery being damaged is a good point.
(in reply to zzz12)
       Post #: 35
RE: E-flite Hawker Sea Fury 400 ARF - 7/16/2008 11:35:16 AM
zzz12
Status: offline
Hello checked the plane out on floor with power on full . And some time the Ailerons move up and down fast. glitches? . I move the antenna to.
       Post #: 36
RE: E-flite Hawker Sea Fury 400 ARF - 7/17/2008 10:15:00 AM
zzz12
Status: offline
Its not the receiver .
(in reply to zzz12)
       Post #: 37
RE: E-flite Hawker Sea Fury 400 ARF - 7/18/2008 2:25:45 AM
doug.jeff
Status: online
Try a good battery.
(in reply to zzz12)
       Post #: 38
RE: E-flite Hawker Sea Fury 400 ARF - 7/18/2008 3:55:09 AM
David Eichstedt
Status: offline
quote:
ORIGINAL: zzz12
Well, if it happens with the motor on but not with the motor off, they aren't glitches (interference from an outside source) but it's electromagnetic interference (EMI), which is interference from an internal source.
Check the routing of your aileron leads. Do they go nearby the battery leads? If so the magnetic field created by the power flowing through the battery leads could be creating problems with the aileron signals.
David
(in reply to zzz12)
       Post #: 39
RE: E-flite Hawker Sea Fury 400 ARF - 7/26/2008 4:11:21 PM
zzz12
Status: offline
THE SEA FURY IS DEAD DEAD DEAD DEAD , THIS PLANE IS MAKED BAD GET A PARKZONE T-28 OR NEW ONE COME OUT...............
