E-flite Hawker Sea Fury 400 ARF
Tower Hobbies
Logged in as Guest
Users viewing this topic: doug.jeff
  Printable Version
All Forums >> Electric Aircraft Universe >> Park Flyers & Backyard Flyers >> E-flite Hawker Sea Fury 400 ARF Page: [1] 2 3   next >   >>
Login
E-flite Hawker Sea Fury 400 ARF - 6/17/2008 10:58:00 AM
zzz12
Status: offline
E-flite Hawker Sea Fury 400 ARF Looks good
Click to see fullsize image.
Click for fullsize
       Post #: 1
RE: E-flite Hawker Sea Fury 400 ARF - 6/17/2008 11:03:21 AM
zzz12
Status: offline
more pic
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to zzz12)
       Post #: 2
RE: E-flite Hawker Sea Fury 400 ARF - 6/17/2008 9:29:14 PM
rusty_y2k2
Status: offline
nice!
Any more info about this?
n/m found the page http://www.e-fliterc.com/Products/Default.aspx?ProdID=EFL6050
Might be something to look to after my trojan has reached it's potential
< Message edited by rusty_y2k2 -- 6/17/2008 9:32:13 PM >
(in reply to zzz12)
       Post #: 3
RE: E-flite Hawker Sea Fury 400 ARF - 6/18/2008 5:26:11 AM
gene465
Status: offline
Just got mine today, looks like a very nice plan, assembly starts tommorrow, Gene
_____________________________
T-Rex 450SE, 450SA, Sea Fury 400, P-47D, Lancair ES, Ultra Mini Stick, Taylorcraft 450, Traxxas Revo
(in reply to rusty_y2k2)
       Post #: 4
RE: E-flite Hawker Sea Fury 400 ARF - 6/18/2008 6:11:08 AM
divergoff
Status: offline
I have been looking into this plane. I had an eflite p-47 and hated the quality of the plane, the foam broke very easily. Is the sea fury made of the same foam?
(in reply to gene465)
       Post #: 5
RE: E-flite Hawker Sea Fury 400 ARF - 6/18/2008 6:17:41 AM
gene465
Status: offline
Diver, I have not seen the P-47 but the Sea Fury is made of foam. Looks well put together. Gene
(in reply to divergoff)
       Post #: 6
RE: E-flite Hawker Sea Fury 400 ARF - 6/20/2008 4:15:55 AM
divergoff
Status: offline
to bad. The P-47 was OK. the stick motor mount was a nightmare though. It always came loose and it seemed like ever 5-6 flights you would have to re-glue it, owell I can "save" a few dollars in that case.
       Post #: 7
RE: E-flite Hawker Sea Fury 400 ARF - 6/22/2008 10:07:19 AM
zzz12
Status: offline
Westen Park Model Airshow uk. Brimgham England. The New Sea Fury E-flite.
Click for fullsize
Click for fullsize
       Post #: 8
RE: E-flite Hawker Sea Fury 400 ARF - 6/22/2008 2:00:11 PM
zzz12
Status: offline
Who has this plane would like to see some home videos of it flying. I am working on my E-Flite Hawker Sea Fury waiting for parts to get her in the air. Would like help........
(in reply to zzz12)
       Post #: 9
RE: E-flite Hawker Sea Fury 400 ARF - 6/23/2008 2:07:10 PM
netdudeuk
Status: offline
quote:
ORIGINAL: divergoff
Not any more. The stick goes through a ply plate attached to the firewall. The stick's going nowhere.
The foam looks like the same as the foam used in the P-47
       Post #: 10
RE: E-flite Hawker Sea Fury 400 ARF - 6/28/2008 9:56:14 PM
doug.jeff
Status: online
Just flew first flights on it today. Flies like a dream. Required no trim. Retracts work great. Plane is very gentle no bad tendencies.
(in reply to netdudeuk)
       Post #: 11
RE: E-flite Hawker Sea Fury 400 ARF - 6/29/2008 11:40:26 AM
zzz12
Status: offline
Can some one put a home video of this bird flying plz .
(in reply to doug.jeff)
       Post #: 12
RE: E-flite Hawker Sea Fury 400 ARF - 6/29/2008 1:58:51 PM
baileym76
Status: offline
Those of you that have one of these birds, what motor, ESC and Servo combos are you using, and how are the results?
(in reply to zzz12)
       Post #: 13
RE: E-flite Hawker Sea Fury 400 ARF - 6/30/2008 1:50:02 AM
doug.jeff
Status: online
I will try to get some video this week. As far as set up I am using the Eflite 480 1020 kv spinning an 11X8 APC Prop, Castle thunderbird 36 speed controller, Castle B.E.C. (not sure if one is needed but with 6 servos its cheap insurance), a Flight Power 2170 pack, 2 JR 241 for the retracts, 4 Hitec 56's on everything else. I am In Denver, CO. At this altitude with this setup plane has unlimited vertical at full power and leaps of the ground in about 10 feet.
< Message edited by doug.jeff -- 6/30/2008 1:51:12 AM >
(in reply to baileym76)
       Post #: 14
RE: E-flite Hawker Sea Fury 400 ARF - 7/2/2008 4:02:27 PM
zzz12
