What do I need to make the Baja 5B SS complete?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Giant Scale Cars >> What do I need to make the Baja 5B SS complete? Page: [1]
Login
What do I need to make the Baja 5B SS complete? - 6/17/2008 8:19:19 PM
clamber
Status: offline
Okay, so I was saving for the RTR version, but now I think I want the 26 so I am going with the kit. But this is my first kit so what else do I need to complete it.
Links would be great.
Thanks.
< Message edited by clamber -- 6/17/2008 8:21:01 PM >
       Post #: 1
RE: What do I need to make the Baja 5B SS complete? - 6/17/2008 8:39:58 PM
DIABLOTAC78
Status: offline
read and search
http://www.rcuniverse.com/forum/m_7606808/tm.htm
(in reply to clamber)
       Post #: 2
RE: What do I need to make the Baja 5B SS complete? - 6/17/2008 8:41:00 PM
DIABLOTAC78
Status: offline
welcome to the large scale hobby by the way
(in reply to DIABLOTAC78)
       Post #: 3
RE: What do I need to make the Baja 5B SS complete? - 6/17/2008 8:47:09 PM
nothinbetr2do
Status: offline
you will need a remote, a receiver, a batt, a on/off switch, and a servo for the throttle/brake
_____________________________
just say no to "shelf queens"
       Post #: 4
RE: What do I need to make the Baja 5B SS complete? - 6/17/2008 8:52:02 PM
clamber
Status: offline
I have no clue what to look for when looking for those things and which ones will work properly. Where is a good site to look for them at?
(in reply to nothinbetr2do)
       Post #: 5
RE: What do I need to make the Baja 5B SS complete? - 6/18/2008 4:14:49 AM
kryptonite5b
Status: offline
quote:
ORIGINAL: clamber
these are bottom line links. this is just the basics to get you started. you will be happier with a better reciever pack and radio. you need a good 200 oz servo. this is what i have in my ss. i went with the bare minumum and it works great. wish i got a better radio, but it works fine. youll also need a fail safe, battery charger for the reciever pack. i use a standard peak charger. the rtr comes with all that stuff as well as a faisafe. but you'll be hapier with the 26cc over the 23cc. hope this helps
http://www.davesmotors.com/store/product1451.html
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXGAG2**&P=SM
http://www3.towerhobbies.com/cgi-bin/wti0001p?&P=SM&I=LXUZ89
sponsored by: vsmodelsport.com
scanner-rc
       Post #: 6
RE: What do I need to make the Baja 5B SS complete? - 6/18/2008 5:16:57 AM
clamber
Status: offline
I will probobly be able to afford this:
Is this everything Ill need to get it up and running?:
http://www3.towerhobbies.com/cgi-bin...?&I=LXTCV2&P=6
http://www3.towerhobbies.com/cgi-bin...?&I=LXRMR3&P=M
http://www3.towerhobbies.com/cgi-bin...?&I=LXPZT7&P=M
http://www3.towerhobbies.com/cgi-bin...I=ASCM9167&P=K
Also, what is a failsafe?
(in reply to kryptonite5b)
       Post #: 7
RE: What do I need to make the Baja 5B SS complete? - 6/18/2008 8:29:34 AM
Foxy
Status: offline
There are three or more different types of failsafe, ranging in functionality. The main categories are failsafes are those which apply brakes in the event of:
  • signal loss only (if you go out of range, or have a TX problem, the car automatically brakes)
  • signal loss and low voltage (same as above, but also activates and applies brakes when your receiver battery runs out)
  • Signal loss, low voltage with engine cut off (all of above, except, in the event of any kind of radio interruption/failure, the car applies brakes AND switches off the engine instantly).
I highly recommend investing the extra $10 or so, in a failsafe which cuts the engine off. A runaway 25lb car at 40mph is likely to do serious damage to anything it hits, including people, property and small children, who have a habit of getting too close. You have been warned.
Foxy. RCU Car Forums Moderator.
"Artificial Intelligence is no match for genuine stupidity".
Check out my Large Scale Gas RC Car Vids... www.youtube.com/foxy4242
       Post #: 8
RE: What do I need to make the Baja 5B SS complete? - 6/18/2008 11:02:16 AM
splcrazy
Status: offline
if i was gonna buy another baja id keep it simple , DDM rear pipe , turtle racing HD front & rear shock support mounts better thicker shock shafts , front & rear alloy arm sets , DS axle dogbones axles , ss diff , esp raceported 36mm head kit, 2mm stuffed stoker , alloy clutch carrier from vertigo, Spektrum DX3R radio ..........
(in reply to Foxy)
       Post #: 9
RE: What do I need to make the Baja 5B SS complete? - 6/18/2008 3:02:06 PM
FastEddy
Status: offline
Lots of great info on this forum about getting started in this hobby.
To help make it easier for people jut like you I am in the process of creating a series of videos that will answer many of your questions.
Take a look,come back here and any un-answered questions can be answered,
http://www.hpibajatutorials.com/showthread.php?t=7
< Message edited by FastEddy -- 6/18/2008 3:03:14 PM >
Owner
TeamFastEddy
(in reply to splcrazy)
       Post #: 10
RE: What do I need to make the Baja 5B SS complete? - 6/18/2008 5:13:10 PM
Dave ESPI
Status: offline
one of 2 things..........
A SHELF (and a crown)
OR
A LOT OF DIRT (and the need to get sloppy and add some "Character" to you beast!)
Queen or Basher, its up to you
Queens are expensive and look nice, but the fun factor is missing. A true 'ja owner gets dirt everywhere, and has to clean their cars with a power washer and toothbrushes
HIROBO SRB QUARK = Heli of the year. Seriously; if you hate always fixing your helicopters, you will LOVE this one !
(in reply to FastEddy)
       Post #: 11
RE: What do I need to make the Baja 5B SS complete? - 6/18/2008 5:31:55 PM
clamber
Status: offline
Wow fasteddy. That was really helpful.
Does the radio I posted have a reciever that comes with it, or do I have to buy one?
(in reply to Dave ESPI)
       Post #: 12
RE: What do I need to make the Baja 5B SS complete? - 6/20/2008 1:51:02 AM
NitroNate
Status: online
http://www.innovativehobby.com/index.asp?PageAction=VIEWPROD&ProdID=913 Is this going to fit around the HPI baja airfilter?
I'm planning on gettin the SS kit soon.CAN"T WAIT!!!!!!!!!!!!!
BREWING UP A STORM
       Post #: 13
RE: What do I need to make the Baja 5B SS complete? - 6/20/2008 1:57:33 AM
nothinbetr2do
Status: offline
quote:
ORIGINAL: clamber
none of your above tower links are working for me, this could be why your not getting an answer
       Post #: 14
RE: What do I need to make the Baja 5B SS complete? - 6/20/2008 2:01:36 AM
nothinbetr2do
Status: offline
quote:
ORIGINAL: NitroNate
yes, that it the one. while your at it, there is one made for the pull starter to
(in reply to NitroNate)
       Post #: 15
RE: What do I need to make the Baja 5B SS complete? - 6/20/2008 2:51:39 PM
FastEddy
Status: offline
quote:
ORIGINAL: clamber
