Adding weight in front tires
Tower Hobbies
Logged in as Guest
  Printable Version
FS Racing Touring Car 2WD 1/5 Scale BLUE - RTR
Seller:  pmwtrading
Details:   $699.00   |  8/10/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Rock Crawlers >> Adding weight in front tires
Page: [1]
Login
Adding weight in front tires - 6/18/2008 5:18:12 AM
jlanders001
Status: offline
Hi. I'm kinda new to rock crawling so I have a question or two or three.
1. How much weight in oz. do people add to the front tires for slow-speed crawling?
2. Which type of weight is best? BBs? Strip weights like they sell at Tower?
3. How does one use BBs? Are you supposed to use them with or without foam? Star cut?..or what?
Thanks guys!!!
Edit: Axial AX-10 is what I have if that matters.
       Post #: 1
RE: Adding weight in front tires - 6/18/2008 8:53:54 PM
K_B
Status: offline
How much weight is personal preference. I see guys run around 6 oz in each front wheel on average.
Brass BBs aren't used that much anymore. Airsoft BBs are still used regularly as far as I can tell. On my scaler, I run no foams with the tires filled as much as I can with Airsoft BBs. That results in around 6 oz per tire and the thing climbs like a goat. I run stick-on weight on my comp crawler. 6oz in each front and about 3oz in each rear.
Experimentation is the only way to find an ideal setup that works for you.
_____________________________
Anchorage Radio Operated Auto Racing
http://www.aroararacing.org
(in reply to jlanders001)
       Post #: 2
RE: Adding weight in front tires - 6/18/2008 10:35:01 PM
Super Mud
Status: offline
Yea, thts all the fun of it, experimenting, especially since thts better to find out wat setup works best with your crawler and where u crawl.
(in reply to K_B)
       Post #: 3
RE: Adding weight in front tires - 6/19/2008 6:49:00 AM
ludog
Status: offline
It all depends on your style of crawling. I have 4.5oz each on front ,and 2 1/4oz on the back. good luck ! and have fun !
(in reply to Super Mud)
       Post #: 4
RE: Adding weight in front tires - 6/19/2008 2:08:29 PM
TFancher
Status: offline
I run 9oz in each front tire and 4 oz in each rear tire.
(in reply to ludog)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.453RCU1
