pythonfan
FL, USA Status: online
quote:
ORIGINAL: holson JB COMP Thanks for the reply - I looked at the links that you sent me. I want the OS CV since I had always had good luck with OS engines (OS .21 RZ-B, .15LD-X, FS-26SC). They were all very easy to tune, holds tune and ran very well. But the Tower hobbies engine comes with muffler and all, seems like really good value. Alternatively, I have kyosho pureten with a GS-11R. I don't use that car much, I may just take the engine and ebay the chassis. My only reason for preserving the GS-11 is the car's drivetrain.. it just seems fragile. I feel that a powerful motor would break something. Here's a shot of the internal from the back plate The bushing seems to be a size that cannot be replace with a ball bearing.... jb, first things first not one of those motors will just bolt up, kyosho puts all there mounts in the case, meaning he would need to find the optional motor mount for that car... and that would be a task in it self. holson, that was a great find, its in amazing condition man. the engine looks good, there's nothing wrong with a thin coat of oil, and from the looks it looks to have been already sealed. for the internals you would have to check ebay or know the exact part number and try it in google. now on the con rod i would not put a bearing in there for the fact, that, if the bearing comes apart you will have a mess on your hands, why do you think all the top motors still use bushings? its a lot safer and stronger. now the front seal, do you mean the front bearing then its probably worn out and that's why its leaking, for that all you would need is a new bearing. if you can find the size of it I'm sure there are plenty of sites that will have the bearing for it.
_____________________________
Savage X SS, Picco P3 .28, Newest Ride Coming Oct 15th!!!
