mboland
Joined: 7/20/2007 From: BouldercombeQueensland, AUSTRALIA Status: offline
Heat gun, or hot air gun, you can even use a hair dryer, but unless they have a dial in temp setting you have to be very careful. For ages I just used a standard clothes iron. adjust the heat settings very slowly, starting low, until you get a satisfactory shrink. If you have it too hot you will get a hole. Try using some scrap on a piece of balsa or other material to get your temp right. Low setting should give you stick without much shrink, slightly higher gives the shrink you will require.
_____________________________
It's the quality of life that counts, not the quantity.
