OS 200fs in pattern plane?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> OS 200fs in pattern plane?
Page: [1]
Login
OS 200fs in pattern plane? - 6/18/2008 8:04:13 PM
BTerry
Status: offline
I want a power upgrade for a pattern plane. I currently have an old YS 1.20NC and was looking at a YS 1.40 Sport.
I realize the 1.60/1.70DZ engines are the very best out there in terms of power.
However, is the OS 200fs a valid replacement for the 1.40 sport?
I think the OS will give me the capability to swing huge props (15x12 3-blade, 18x10 - 20x8, etc) on slightly less expensive fuel (15%) for similar power to the 1.40 on 30%, weighs about the same or less, and also costs a bit less than the 1.40. Maintenance on the OS should be minimal, similar to the .91 and 1.20 Surpass. I would like a simple, light, powerful plug-and-play system.
Any comments?
Thanks!
Brett
       Post #: 1
RE: OS 200fs in pattern plane? - 6/18/2008 8:13:11 PM
ual767
Status: online
So far I have not seen or heard of a single person running the OS 200 other than Jason who ran one for 1/2 flight last year at the NATS. Not sure why nobody is running it but they are not.
_____________________________
Sponsored by my personal bank account
(in reply to BTerry)
       Post #: 2
RE: OS 200fs in pattern plane? - 6/18/2008 8:19:11 PM
J Lachowski
Status: offline
Why not OS 140RX or for that matter OS 160. The OS140RX is the most reliable straight forward glow motor going.
17X12 or 18.1X10 prop on 15 to 20 percent nitro. Definitely adequate through Masters.
Joe Lachowski
NSRCA 330
(in reply to ual767)
       Post #: 3
RE: OS 200fs in pattern plane? - 6/18/2008 8:59:46 PM
wagen017
Status: offline
not too fast, I like the 4-strokes a lot. YS in Europe is not much of an option. Expensive to run on 30% nitro and unless you have people around that understand them, they can be a nightmare.
It would be nice to see an alternative. Unfortunately Saito does not offer yet anything. I would be interested to hear about experience with the FS in pattern.
Club Saito member #371
(in reply to J Lachowski)
       Post #: 4
RE: OS 200fs in pattern plane? - 6/18/2008 9:35:20 PM
BTerry
Status: offline
quote:
ORIGINAL: J Lachowski
Joe, thanks for the info. I had a big response typed up and the computer froze.
That 1.40rx is definitely a great engine. I love the performance of the big OS 2-strokes on 5% - 15%. I had a 1.60 with mixed results due to the Pitts muffler (deadsticks), but it handled very well. I especially loved the 12+ minute flights on 14 oz of fuel. I could probably get a NIB 1.60fx, bearing, pump, pipe, header for about $500 or so.
The 1.40RX is an excellent option too. It has two problems though. It requires that I purchase a full-length pipe ($160 - $275) and it requires that I install said pipe (long pipe tunnel). I see the engines for sale from time to time used, but buying new will cost as much as a 1.70DZ.
On a side note, I am interested to see if OS follows suit and releases a big AX series engine (1.80AX? 200AX?)
My plane has a short pipe tunnel for the short 4-stroke pipe. I want a relatively plug-and-play option. I know the 2-strokes will blow it away on power, but power is adequate and it is easy to live with and costs $399.
       Post #: 5
RE: OS 200fs in pattern plane? - 6/18/2008 10:49:40 PM
J Lachowski
Status: offline
Maybe as much as the DZ without its exhaust system<g>
It's funny more times than not you get what you pay for.
Joe Lachowski
NSRCA 330
       Post #: 6
RE: OS 200fs in pattern plane? - 6/18/2008 11:48:49 PM
hurrejola
Status: offline
Hi Brett:
In my field, a good friend purchased the 200 and is a wonderful engine!!!!
Power wise, is about the same as the YS sport, as he told me.
Grate engine!!!!
Hector
       Post #: 7
RE: OS 200fs in pattern plane? - 6/19/2008 12:15:26 AM
Robbidos
Status: offline
So power wise you are saying it is close to the power of a YS 1.40 Sport??!? Wow, for the money and weight (almost 2 oz heavier) I would have at least expected it to be close to the 1.70DZ. Who would want that?
< Message edited by Robbidos -- 6/19/2008 12:19:06 AM >
- Robert Beaubien
- Sun Valley Fliers
(in reply to hurrejola)
       Post #: 8
RE: OS 200fs in pattern plane? - 6/19/2008 12:29:55 AM
RC_Pattern_Flyer
Status: offline
Ron Barr in Texas is running the OS 200 FI and it is incredible. Power to the MAX.
Chuck
Mark Hunt Designs
(in reply to Robbidos)
       Post #: 9
RE: OS 200fs in pattern plane? - 6/19/2008 2:26:55 AM
BTerry
Status: offline
quote:
ORIGINAL: Robbidos
Robbidos,
I don't understand what you are saying. The OS weighs 1.5 oz more with the stock mufflers, and a little more than an ounce more (40 g) than the YS without mufflers. The OS costs less than the YS too. Reports I have read place the power in the same ballpark as the YS 1.40 sport, but on 15% instead of 30% fuel, with the added capability of swinging a much larger prop more like the 1.60fx. The OS 4-strokes I have owned
Chuck, it is my understanding the 200FI is "supercharged" similar to the YS. Too bad they don't make a carburetted version with the pump and supercharging.
< Message edited by BTerry -- 6/19/2008 2:31:43 AM >
       Post #: 10
RE: OS 200fs in pattern plane? - 6/19/2008 2:39:33 AM
sarashina
Status: offline
I've never heard the example of using 200fs to F3A. But I recently hear that a few pilots began to use the new 200fs-p for F3A in Japan. As you know this type has much power(5% plus) than normal 200fs. However I am not certain if this choice is appropriate or not.
Best regards
Srashina
(in reply to RC_Pattern_Flyer)
       Post #: 11
RE: OS 200fs in pattern plane? - 6/19/2008 3:00:55 AM
BTerry
Status: offline
Srashina, I expect the pump version (200fs-p) will be available in the US soon. It is good to know it has more power than the standard version, thank you for your input!
(in reply to sarashina)
       Post #: 12
RE: OS 200fs in pattern plane? - 6/19/2008 6:40:36 AM
Robbidos
Status: offline
quote:
ORIGINAL: BTerry
quote:
ORIGINAL: Robbidos
Robbidos,
Actually, it weighs 3.5oz heavier (31.75oz vs 35.27oz, neither with the muffler) than the 140sport and costs 3 times as much ($429 vs $1299) as the 140 sport. It is 1.5oz heavier than the 170DZ and it is only $690. Why on earth would anyone use it if that is all it can put out power wise?
- Robert Beaubien
- Sun Valley Fliers
       Post #: 13
RE: OS 200fs in pattern plane? - 6/19/2008 12:16:29 PM
BTerry
Status: offline
You are looking at the fuel injected model ($1200). I refer to the carburetted version ($399), here: http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXPRL4&P=0 . The pump version should be about $60 more and weigh a little under an ounce heavier. The 200fs weighs 32.8 oz and the 1.40 sport weighs 31.75 oz.
As far as power, the 200fs-FI version is supercharged similar to the YS engines and is supposed to be very powerful, although very expensive. I agree I would not use that engine.
       Post #: 14
RE: OS 200fs in pattern plane? - 6/19/2008 2:37:42 PM
bigbuster
