ESC?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric On-Road vehicles, race cars and more >> ESC?
Page: [1]
Login
ESC? - 6/19/2008 4:34:03 AM
xxCARLOSxx
Status: offline
ok so im pretty new to this stuff and i just bought a ta05 IFS-R kit online... my friend sold me a 6c 3600 battery, a traxxas titan 12t and a stock 540 motor that he had for $30 and i was wondering what ESC should i buy that would be relatively cheap... i was looking into one of these (http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXUY13&P=7) or (http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNMM8&P=7) any other suggestions, advice? thnx!
-heres a picture of the stuff i bought from my friend
Click to see fullsize image.
Click for fullsize
       Post #: 1
RE: ESC? - 6/19/2008 12:14:49 PM
TIGER76
Status: offline
That ESC youve picked is a 20+ turn so it wont run that titan 12 turn very well,it will run that stock silver can motor tho.
Look for the mtronik rv 11 its a nice cheap 11+ turn ESC and it will run that titan motor.
The ESC turn limit need to be under the motor turns ie 11t esc for a 12t motor esc
_____________________________
VXL pede/ 9.6v 4600 mAh & 8.4v 4500mAh (x2)
TT-01r / Quake ESC / Trinity D6 9Turn / Orion Rocket Pack 4500 (X2)
(in reply to xxCARLOSxx)
       Post #: 2
RE: ESC? - 6/20/2008 5:43:40 AM
xxCARLOSxx
Status: offline
should i buy the traxxas xl-5 ESC? any other suggestions on cheap ESCs?
(in reply to TIGER76)
       Post #: 3
RE: ESC? - 6/20/2008 11:50:59 AM
The Mad Modder
Status: offline
If you don't mind not being able to run the titan, you could get a Novak XRS.
My RCs: Sledghammer 4x6, M03, Leo-X, Scania, Double Blaze, Mini-Baja, TXT-1.
       Post #: 4
RE: ESC? - 6/20/2008 2:49:26 PM
TIGER76
Status: offline
Novak XRS is a good esc or if u want cheap look for the tazer 12turn good for a budget esc.
Or go all out and get a no limit esc then u can use any brushed motor on it i picked up a ripmax quake for £40 over here and it runs any motor sweet
(in reply to The Mad Modder)
       Post #: 5
RE: ESC? - 6/20/2008 3:06:49 PM
Lunchboxer
Status: offline
Titan 12T is a big can motor.. (550 sized). Probably not ideal for a race car.. but if you want to run it, you'd need an ESC that can handle down to maybe 14T? (since it is 550-sized motor, it does not draw as much current..) But of course, you can always play safe and use an ESC that can handle lower turn motor than 14T..
LB | WW2 | TLT | TB02 | DF03 | TEgg | TC4FT | F103GT | TXT | Hornet | M03M | Frog | Scalpel | Leo 2A6 | Aeromax | WW1 | Clod
       Post #: 6
RE: ESC? - 6/20/2008 4:25:08 PM
xxCARLOSxx
Status: offline
any under $70 that can run both motors? links plz (preferably from towerhobbies)
i was thinking about going with the novak rooster 12t which is a little more expensive but looks like good quality
< Message edited by xxCARLOSxx -- 6/20/2008 4:28:20 PM >
(in reply to Lunchboxer)
       Post #: 7
RE: ESC? - 6/20/2008 6:31:58 PM
Lunchboxer
Status: offline
Maybe spend a few bucks more and get a BL controller (that also do brushed) and you can upgrade to BL motor later on?!
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXUTA0&P=ML
       Post #: 8
RE: ESC? - 6/21/2008 10:06:12 PM
xxCARLOSxx
Status: offline
do i have to weld anything with that one? oh and i dont see anything for the battery connector how would i use that?
< Message edited by xxCARLOSxx -- 6/21/2008 10:08:03 PM >
       Post #: 9
RE: ESC? - 6/23/2008 1:06:04 AM
The Mad Modder
Status: offline
Looks like you'd need to solder on the battery connectors.
       Post #: 10
RE: ESC? - 6/23/2008 7:45:52 AM
TIGER76
Status: offline
^ Yeh will need soldering but u will need decent connectors anyway like deans to run either BL motors or low turn brushed motors might as well learn how now
       Post #: 11
RE: ESC? - 6/23/2008 12:09:03 PM
xxCARLOSxx
Status: offline
i have no soldering equipment or experience.... do i have to solder anything with the novak esc? if so what cables or plugs would i need?
< Message edited by xxCARLOSxx -- 6/24/2008 5:14:06 PM >
       Post #: 12
RE: ESC? - 6/24/2008 5:37:28 PM
Lunchboxer
Status: offline
Probably time to learn how to solder.. it is not hard.. you can get a cheap soldering iron for less than $10..
You probably need that skill if you want to stay in RC..
       Post #: 13
RE: ESC? - 6/24/2008 6:19:59 PM
AutoXMan
Status: offline
Yep time to learn how to solder, check youtube they have excellent tutorials.
< Message edited by AutoXMan -- 6/24/2008 6:21:07 PM >
V-tec rep
       Post #: 14
RE: ESC? - 6/24/2008 8:40:56 PM
