spiral_72
SC, USA Status: offline
quote:
ORIGINAL: OzMo there is a ready made version that hanger 9 I think made. search around and you will find some pics. they are easy enough to make just be sure the release is SMOOTH and build in 2 or 3 degrees of down attitude for the glider being piggy backed. the rubber bands af a trainer wing will hold the cradle down. always release with the tow plane at idle! seach for cradle design by tinkerpilot Yea, I heard a rumor of the Hanger 9 cradle, but I couldn't find it anywhere! The word was a $29 cradle.... Well worth the aggrivation of building one. JoeDoe, That's a clean install man! I notice you don't have any wing tip supports. Obviously you don't have a problem keeping it level. I thought I'd have to make some supports too. Well, I'd like to try this thing. I figured I'd have to use the largest diameter prop I can find (as mentioned) for the pulling power. I think a 12.25x3.75 APC is my best bet. I bet the Pizazz will float with all that secondary wing in tow. Thanks for the parts diagram too. I'll draw this thing up and see what happens. I've already made some sketches. I like the idea of the servo in the glider though. A HS-55 should be more than enough. I use a high start now. The cradle launch is just for the novalty(SP?) of the thing really. It's gonna be great! Thanks all!
_____________________________
Wasn't that cool? I meant to do it.
