lst radio problems?
Tower Hobbies
Logged in as Guest
  Printable Version
FS Racing Monster Truck 4WD 1/5 Scale Blue - RTR
Seller:  pmwtrading
Details:   $755.00   |  8/29/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Losi Monster Trucks >> lst radio problems?
Page: [1]
Login
lst radio problems? - 6/21/2008 4:18:01 AM
danal
Status: offline
any body had problems with lst servos shuttering. my steering servo shutters and when i go to turn it shifts to reverse. ive already replaced reciever, battery pack, and swapped radios. what next servos?
       Post #: 1
RE: lst radio problems? - 6/21/2008 4:37:58 AM
BAJABANDIT
Status: offline
most likely! Try changing frequencys!!
< Message edited by BAJABANDIT -- 6/21/2008 4:39:07 AM >
(in reply to danal)
       Post #: 2
RE: lst radio problems? - 6/21/2008 5:40:23 AM
danal
Status: offline
i did try that i went throught most of the frequencies that it has.
(in reply to BAJABANDIT)
       Post #: 3
RE: lst radio problems? - 6/21/2008 5:42:21 AM
danal
Status: offline
i also removed the original reciever and put it in another car and it worked fine.
(in reply to danal)
       Post #: 4
RE: lst radio problems? - 6/21/2008 5:46:07 AM
danal
Status: offline
could a servo short out like that and send signal from one channel to the other? if so what would be a good way to check it? maybe check the resistance in each servo?
       Post #: 5
RE: lst radio problems? - 6/21/2008 5:55:09 AM
BAJABANDIT
Status: offline
check that and al the wires for nicks in them and check for any thing grounding out
(in reply to danal)
       Post #: 6
RE: lst radio problems? - 6/21/2008 6:19:06 PM
CBM Racing
Status: offline
Just sounds like a simple mix up of the plugs to me. Steering is channel 1, throttle channel 2 and reverse channel 3. The 2 steering servos plug into a y harness that then plugs into channel 1. Also be sure as mentioned that both tx and rx are on the SAME channel. If you switched receivers make sure you use one on the right band and shift, 75mgz band, not 27 or 72. JR and airtronics use the same shift, futaba hitec and some others use a different shift(+ or - shift). They are not compatible with each other and will cause the problems you describe also. Just some ideas so you don't waste money on servos you don't need. If you did change to a different brand receiver, it is probably on a different band width or different shift, meaning it just wont work.
_____________________________
MMmm..Piepants..
       Post #: 7
RE: lst radio problems? - 7/10/2008 8:57:36 PM
MaddMatt
Status: offline
Just swap the servo plugs around and see if the problem follows the servo or the socket it was plugged into.
"The Shocker"
(in reply to danal)
       Post #: 8
RE: lst radio problems? - 7/11/2008 12:29:41 AM
raze44
Status: offline
Make sure that the wires from the receiver pack arnt laying on the chassis, or any other metal/carbon fiber piece. That was happening to me when I first bought my truck, so I mounted it on top of the receiver box thingy on the front( ). Just to be sure, are your servos going crazy and glitching? Or is it just that the servos wont do what your trying to make it do?
Aftershock w/LST2 upgrade + LRP , Raze, Evader ST, RC10T
(in reply to MaddMatt)
       Post #: 9
RE: lst radio problems? - 7/11/2008 2:07:38 AM
nitronut911
Status: offline
make sure the servos dont have any major water dammage. that makes them do interesting things!
When your over 65, NEVER trust a fart!
(in reply to raze44)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.469RCU1
