Jetscream sharing a Tx?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Indoor & Micro RC Flight >> Jetscream sharing a Tx?
Page: [1]
Login
Jetscream sharing a Tx? - 6/21/2008 4:06 PM
Brewerpaul
Score: 100
Last Login: 12/27/2010
Status: offline
For some reason, my new Jetscream transmitter has totally pooped out. Even with new batteries the power light does not come on at all.
I have two other similar transmitters, both on 27Mhz (I assume the numbers past the decimal point don't matter, right?) and would think that I could use one of them to charge and fly the Jetscream, but I guess I'm thinking wrong... When I plug them in, neither of them switches to CHARGE mode. One of them has a switchable channel mod (courtesy of Ferndale), but that doesn't work either. Both of them work fine with their designated planes (Aero Ace and that Radio Shack Transformer "Jet").
Any ideas?
_____________________________
Rainy day? Can't fly? Make some music instead!
www.busmanwhistles.com
Hide Signatures
       Post #: 1
RE: Jetscream sharing a Tx? - 6/22/2008 12:34 AM
FERNDALE AIR FORCE
Score: 115
Last Login: 3/2/2012
Status: offline
Paul, is the jetscream controller the same as the Ace tx? Does it have channels a,b,and c? If so it should be the same tx. The numbers after the 27 signify the frequency. I misread your post earlier. Let me see what I can find out about the jetscream.
Tim
OK, after a bit of poking around it seems the tx is not the same. So you would need another controller with 27.xxx to match the plane. It just quit? I would open it up and see if a wire joint got unplugged. If I had to guess a wire to the battery box.
Good luck,
Tim
< Message edited by FERNDALE AIR FORCE -- 6/22/2008 12:46 AM >
"...never stop flying the airplane..."
Hide Signatures
(in reply to Brewerpaul)
       Post #: 2
RE: Jetscream sharing a Tx? - 6/22/2008 5:58 AM
Brewerpaul
Score: 100
Status: offline
>>OK, after a bit of poking around it seems the tx is not the same. So you would need another controller with 27.xxx to match the plane. It just >>quit? I would open it up and see if a wire joint got unplugged. If I had to guess a wire to the battery box.
Yeah Fern, it just quit. I took the plane and tranny home after a minor crash and when I tried to charge the plane the next day, the Tx didn't work. I figgered I had left it ON overnight so I changed the batteries, but it didn't matter. I could understand it if something died in the plane after a crash, but not in the transmitter.
The transmitter looks similar to the modded one you sent me, but not exactly the same. That little AA still flies great, BTW and these days is my only successfully flying plane. That Radio Shack jet is not bad, but has an extremely short range. The plane is fairly fast, so it goes out of range quickly and I'm not good enough to keep it close in. It really looks jetlike when it's airborne.
In my spare time (har, har) I'll take your advice and open up the transmitter and look for a loose something or other.
Hide Signatures
       Post #: 3
RE: Jetscream sharing a Tx? - 6/22/2008 7:08 PM
FERNDALE AIR FORCE
Score: 115
Status: offline
Alrighty. You might want to try the x-twin jet, loads of fun.
Tim
Hide Signatures
       Post #: 4
RE: Jetscream sharing a Tx? - 6/22/2008 8:35 PM
crazychris46dividedby2
Score: 115
Last Login: 7/3/2009
Status: offline
im not sure if this helps you out at all but i use my jetscream controller to fly my channel "A" aero ace. so im guessing it would work in reverse as well. if you have the channel "A" aero ace then try using it to fly the jetscream, best of luck to ya, chris
IF YOU CANT BEAT IT..............................MOD IT.
Hide Signatures
(in reply to FERNDALE AIR FORCE)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.563RCU1
