Nitro 4 Tec Chassis
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> Nitro 4 Tec Chassis
Page: [1]
Login
Nitro 4 Tec Chassis - 6/21/2008 5:35:44 PM
slurp91193
Status: offline
ok so i got a used nitro 4 tec .15 on the way. im planning on doing some upgrades and was wonddering if the new 3.3 chassis will work on the .15 4 tec. im gonna put a 3.3 in it. new tires. 3.3 body. and some little things like that.
any suggestions. new to on road.
_____________________________
- TRAXXAS ALL THE WAY -
- 3 TRAXXAS REVO 3.3''S
       Post #: 1
RE: Nitro 4 Tec Chassis - 6/21/2008 9:12:33 PM
thomas09
Status: offline
I just ripped apart my old 4Tec .15 for a decent clean. Gotta finish it today.
(in reply to slurp91193)
       Post #: 2
RE: Nitro 4 Tec Chassis - 6/21/2008 11:30:28 PM
turbodremz23
Status: offline
yes..everything is compatible. look at my photo album and you will see that I have the older .15 pro chassis with a 2.5R on it, 3.3 front and rear diffs. the only thing you need to make it all work is the 2.5 or 3.3 throttle/brake linkages. the plus side is unlike the 2.5 chassis, the .15 pro chassis has the same gears on the pulley...20t instead of the 15t that came on the 2.5 chassis.
there were no major changes in any of the chassis, except the radio tray cover, color of the plastic decks, and the gears on the 2.5 chassis.
a couple of tips for better power and handling
dont use the traxxas header pipe..its a really small i.d. and restricts the crap out of it, i dont care what anyone says...on my 2.5R I used the header from a Yokomo GT4 II, and a standard exhaust coupler spring...made one hell of a difference in the bottom and mid range power band.
you can also use the Yokomo GT4 II aluminum shocks...they work wonders....
look at my album, and if you have any questions feel free to email me...I was hitting 90+ mph with my 4-Tec until I killed the piston, but I have alot of little tips and tricks that will help with your conversion.
(in reply to thomas09)
       Post #: 3
RE: Nitro 4 Tec Chassis - 6/22/2008 2:41:01 AM
thomas09
Status: offline
Sorry for a bit of a thread derailment, but can I use offroad tires on my Nitro 4-tec onroad rims? Will they give me more ground clearance i.e make the car sit higher up? The roads around my house are not smoothly paved but more a mix of gravel and tar.
(in reply to turbodremz23)
       Post #: 4
RE: Nitro 4 Tec Chassis - 6/22/2008 3:28:59 AM
turbodremz23
Status: offline
you can, but be sure to trim the body accordingly...you can use the Tamiya rally tires too...
       Post #: 5
RE: Nitro 4 Tec Chassis - 6/25/2008 7:41:17 PM
slurp91193
Status: offline
do they make bigger tires and wheels for on road cars.
       Post #: 6
RE: Nitro 4 Tec Chassis - 6/25/2008 9:11:14 PM
snowbl!nd
Status: online
quote:
ORIGINAL: slurp91193
Wheels and tires are generally all of the same size, with varying degrees of offset. Rally tread tyres by their nature should have a slightly greater external circumference.
RC obsession. The quest to discover just how deep those pockets really are...
Life is short - Drive fast.
       Post #: 7
RE: Nitro 4 Tec Chassis - 6/25/2008 9:21:17 PM
turbodremz23
Status: offline
you can also use 1/8 wheels/tires, but you will need to find the hub adapters that are compatible with the 4-Tec chassis. I have seen them before, I will try to find the link for you
(in reply to snowbl!nd)
       Post #: 8
RE: Nitro 4 Tec Chassis - 6/25/2008 10:04:00 PM
slurp91193
Status: offline
thanks
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
3.125RCU1
