LOW RPM START SHUT DOWN on Titan SE
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Jets >> Turbine Clinic >> JetCat Turbine Direct Support >> LOW RPM START SHUT DOWN on Titan SE Page: [1]
Login
LOW RPM START SHUT DOWN on Titan SE - 6/22/2008 12:49:02 AM
HOVERLOVER
Status: offline
HI Guys, Mr. Matt,
I just installed my Titan SE which was sent in for upgrade to 6.0 J. one detail, I took out the front board with the starter case and assembly (the whole thing). and sent it in for upgrade. the upgrade invoice said to redo temp probe calibration and rc check. Today is quite hot app. 95 deg f around here. So I got some ice and IR thermometer to lower the probe temp down. I dont think IR thermometer is giving me accureate measurements, however I cooled the thermocouple and redid the calibration and rc check.
THE PROBLEM. LOW RPM Start shut down. I do have ignition and then immediate shutdown.
I have noticed one issue. I checked against my P70 kero start which runs perfectly. In the idle state, when I press Ignition/Starter to turn the turbine manually, the rpm indicator start displaying the rpm once it picks up a bit of speed. however, in the titan, it shows zero, even if i hold it for 3 full seconds.
Is it the optical sensor or the board?? are there any settings that effect the RPM readout or cause LOW RPM Fault condition?
thanks
jason
< Message edited by HOVERLOVER -- 6/22/2008 5:55:00 PM >
       Post #: 1
RE: LOW RPM START SHUT DOWN on Titan SE - 6/25/2008 4:52:14 AM
mr_matt
Status: offline
HI Jason,
I am looking into it for you. Have you tried a different black data cable? They are all the same so you can try another one. The RPM should read out when manually spinning the turbine so try to rule out a bad cable or cable connector first.
Regards,
_____________________________
Matt
JetCat rep
(in reply to HOVERLOVER)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.281RCU1
