Plane for Windy Conditions?!
Tower Hobbies
Logged in as Guest
  Printable Version
Jet Hangar Hobbies LTV A-7 Corsair II - RTF
Seller:  mikegpresario
Details:   $2,850.00   |  8/26/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Questions and Answers >> Plane for Windy Conditions?!
Page: [1]
Login
Plane for Windy Conditions?! - 6/22/2008 1:55:41 AM
KINGX
Status: offline
Hi to all,
I have flown so far many and various types of models and i still quite have not found one that can handle highly windy conditions with confidence. I am not into sailplanes, so i am looking for a glow model that i can take to the field when the rest of my planes are grounded because of high winds. Mind you that i do fly pattern planes and they are my favorite ones for flying in windy situations but i am looking for a plane that is not pattern and can fly better in high winds! Does such a plane exist?! Please let me know if it does!
Your suggestions and advice are really appreciated.
< Message edited by KINGX -- 6/22/2008 1:56:56 AM >
       Post #: 1
RE: Plane for Windy Conditions?! - 6/22/2008 2:08:15 AM
Live Wire
Status: offline
KINGX
We fly large trainers here like the SIG Senior Kadet, With a few mods and flatten out the wing a little with larger tires to make the CG lower with a wide stance.
_____________________________
Larry K AMA 36417
WACO Brotherhood #34
(in reply to KINGX)
       Post #: 2
RE: Plane for Windy Conditions?! - 6/22/2008 2:42:43 AM
ChuckW
Status: offline
Bigger and heavier works better in the wind from what I have experienced.
(in reply to KINGX)
       Post #: 3
RE: Plane for Windy Conditions?! - 6/22/2008 2:42:47 AM
EZer
Status: offline
For me it dont really matter about the wind, I say the wind is your friend. For an easy flying plane in the wind is the P51, I fly them fast and land them fast its alot of fun.
(in reply to Live Wire)
       Post #: 4
RE: Plane for Windy Conditions?! - 6/22/2008 3:01:42 AM
PilotFighter
Status: offline
Sig Kougar. Flys great in up to 30 knots of wind and lands easily to.
turn left, your other left
(in reply to EZer)
       Post #: 5
RE: Plane for Windy Conditions?! - 6/22/2008 10:15:32 AM
jetmech05
Status: offline
heavier and bigger work for me
(in reply to PilotFighter)
       Post #: 6
RE: Plane for Windy Conditions?! - 6/22/2008 2:22:13 PM
bkdavy
Status: offline
SPADS (Simple Plastic Airplane Design). They tend to be heavier, but they are brutally tough. No they don't have the scale appearance, but when you want to fly in higher winds, you can't beat 'em.
Brad
(in reply to jetmech05)
       Post #: 7
RE: Plane for Windy Conditions?! - 6/22/2008 3:20:48 PM
Villa
Status: offline
Hello KINGX
From your original question you apparently know that the best plane for high winds is a pattern plane. You also know that high winds can be unpredictable and will occasionaly smash a plane into the ground. What you need is a tough plane, one that can survive being beaten into th ground. All of my SPAD planes are that tough. I fly my SPAD Twin Tail in any wind I can safely stand up in. See http://www.rcuniverse.com/forum/m_7019698/anchors_7019698/mpage_1/key_spad%252Ctwin%252Ctail/anchor/tm.htm#7019698
I find that if I am not worrying about smashing the plane I can better fly in high and gusting winds and have a very good time.
(in reply to bkdavy)
       Post #: 8
RE: Plane for Windy Conditions?! - 6/23/2008 6:55:13 PM
carlgrover
Status: offline
I'll second the Sig Kougar. Flew it in windy conditions many times.
(in reply to Villa)
       Post #: 9
RE: Plane for Windy Conditions?! - 6/24/2008 3:25:54 AM
Gray Beard
Status: offline
For just Plane Fun I like the Sr. Telemaster, you can get it to fly backwards.
I don't have A Telemaster any longer so I reach for my old Bridi Kaos 60 with the OS .91 FS on it. Wind doesn't bother it much at all unless it's A very strong cross wind and then only when landing but that would bother any plane built.
I have noticed that none of the Extras I have ever flown were bothered by the wind too much either.
If drinking and driving are illegal, then why do bars have parking lots???
(in reply to carlgrover)
       Post #: 10
RE: Plane for Windy Conditions?! - 6/24/2008 5:17:36 PM
racer8297
Status: offline
My turbine is hardly affected by winds. Heck, I look forward to windy days! It makes it easier to land .
Jim
(in reply to Gray Beard)
       Post #: 11
RE: Plane for Windy Conditions?! - 6/25/2008 3:36:38 AM
Villa
Status: offline
Hi racer8297
I'm interested in a turbine also, but have never had one. Can you explain how/why the turbine is better in high, erratic winds as compared to a regular prop plane? Does the turbine accelerate the plane as fast as a prop plane in order to get out of a bad condition during a landing?
(in reply to racer8297)
       Post #: 12
RE: Plane for Windy Conditions?! - 6/25/2008 12:37:31 PM
racer8297
Status: offline
There are a few reasons why it is better in the wind. First, the wing loading is less than most prop planes. The airframe is cleaner, the wings thinner, etc. Generally, for their relative size the jets are heavier. These characteristics of jets make them more stable in the wind. When landing, a good 20mph headwind makes the landing slower and easier, instead of squirrely like a lightly loaded prop plane.
I am flying the Reaction 54 which is a kit from Bruce Tharpe Engineering. He aslo has an ARF version. The Reaction slows to a crawl for landing yet with the right motor (Jetcat P70 in mine) it will go 170 mph. It is also good for a grass field, which is what I fly from.
No, a turbine does not supply thrust like a prop plane. You have to "set up" for landing well in advance. You have to keep the revs up as you are on final. If all looks good when you cross the runway threshold, you chop the throttle and it settles in. And, you must not push the nose down, a jet will pick up speed in an instant. If you have to do a go around, you need to decide early on. Once you throttle up to full throttle from say 1/4 throttle, it can take every bit of 4 or 5 seconds to actually have enough thrust to abort a missed approach.
It is a different way of flying. You need to anticipate more. But once you get used to it, maybe 10 flights if you are an otherwise experienced pilot, you will love it. No vibration, great sound, feeling of power, and you will know that you have reached the top of the hobby.
Good luck, let us know if you have any questions.
Jim
(in reply to Villa)
       Post #: 13
RE: Plane for Windy Conditions?! - 6/25/2008 4:39:23 PM
Villa
Status: offline
Hi racer8297
Thanks for a very good explanation.
       Post #: 14
RE: Plane for Windy Conditions?! - 6/25/2008 5:23:20 PM
racer8297
Status: offline
Your welcome Villa. Once you go down that road there is no turning back. Welcome to the dark side!
Jim
(in reply to Villa)
