gas engine reversal - is it possible ?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> gas engine reversal - is it possible ?
Page: [1] 2   next >   >>
Login
gas engine reversal - is it possible ? - 6/22/2008 7:31:36 AM
Ravivos
Status: offline
is it possible to reverse the rotation of a single cylinder two stroke gas engine with EI?
I know the first thing to do is to remount the hall sensor so it will be at the same angle but in a CCW insted of CW.
is there anything else to do or retiming the engine is enough ?
the engine is a 26cc gas engine, with EI.
i need it to spin CCW so i can use it as a pusher with an ordinary prop (mounting the prop backwards)
Thank you.
Raviv.
       Post #: 1
RE: gas engine reversal - is it possible ? - 6/22/2008 12:11:00 PM
rc bugman
Status: offline
Just change the position of the ignition sensor and start the engine in the other direction
Have fun
Elson
_____________________________
Using this Hobby for Science (aerobiology)
(in reply to Ravivos)
       Post #: 2
RE: gas engine reversal - is it possible ? - 6/22/2008 3:35:12 PM
soarrich
Status: offline
quote:
ORIGINAL: rc bugman
Or you can leave the sensor where it is, but flip the sensor in the housing, then install a second magnet with the polarity reversed where it should be for reversed timing. From then on to get the othere direction you just reflip the sensor.
Rich Border
(in reply to rc bugman)
       Post #: 3
RE: gas engine reversal - is it possible ? - 6/22/2008 4:22:41 PM
Ravivos
Status: offline
Thank you for your answers,
It seems that the only thing needed in order to make the engine work currectly (but opposite direction) is to re-time it.
What about cooling?
in a pusher mode, the prop pulles air from the cylinder head (instead of pushing air into the cooling fins), could this be a problem?
the modified engine will be mounted as a pusher without any option for baffeling or jacketing,
further more, the plane (actually - VTOL) will spend alot of time hovering and will not have free air flow caused by straight flight.
(in reply to soarrich)
       Post #: 4
RE: gas engine reversal - is it possible ? - 6/22/2008 5:27:08 PM
Tired Old Man
Status: offline
Cooling is a BIG problem with pusher configurations. If you fail to duct the air to the cylinder, fail to maintain a tight fit of a cooling duct around the cylinder, and design the cooling outlet in a manner that will force good extraction you can ruin an engine in short order. Take the time to think the cooling system through and design it with minimum obstruction. Pay particular attention to cooling the exhaust side of the cylinder. Do not use lean oil ratios!! Pusher installations are the true test of what an oil can do so stay with the upper end of the quality selections and avoid ratios leaner than 50-1.
To assist the design of a cooling system you can set up a crude wind tunnel test by using a leaf blower to push air over the airframe. Set a screen in front of the leaf blower and plane with long thin strips of mylar attached to the screen long enough to reach to the back of the aircraft. Watch how the mylar strips flow over the airframe to determine where the natural airflow runs over the plane and use that airflow to determine where a cooling duct should begin to obtain the most volume. After you build the prototype air duct perform the airflow check again to see if it's use had a negative effect on the original flow of air.
If you can''''t fix it with a hammer, you have an electrical problem.
       Post #: 5
RE: gas engine reversal - is it possible ? - 6/22/2008 5:37:38 PM
octanehuffer
Status: online
No need to run an iar cooled engine when MVVS makes a liquid cooled 58cc. Just find a spot for the radiator in open air.
QQ 120" Yak, QQ 86" Evolution, QQ 69" Saito 1.25, QQ 49" 32SX, QQ E-Yak, H9 T-Craft G-26, etc
(in reply to Tired Old Man)
       Post #: 6
RE: gas engine reversal - is it possible ? - 6/22/2008 7:12:06 PM
dirtybird
Status: offline
If the gas engine has a rotary valve like the MVVS or ZDZ you probably cannot reverse it.
Also if the engine has been run for any time in the normal direction, reversing it will create abnormal wear and might ruin it. You need to start with a new engine and always run it reverse.
(in reply to octanehuffer)
       Post #: 7
RE: gas engine reversal - is it possible ? - 6/22/2008 7:16:47 PM
Ravivos
Status: offline
well, i really have no intentions of buying a liquid cooled engine (although it crossed my mined), and i want to use the engine i already have.
hi "old man", thank you for your answer.
It seems that i have a problem, isnt there any other way cooling the engine while hovering?
the plan is to build a shroud that will surround the prop, kinda like a ducted fan... a prop ducted fan,
if the walls of the shroud will be high enough to contain both the prop and the engine itself, wouldnt it be sufficient to force enough air over the cylinder and keep it cool?
p.s, while serching RCU for some VTOL information, i came across some of your threads, a lot of useful information, thank you.
Raviv.
       Post #: 8
RE: gas engine reversal - is it possible ? - 6/22/2008 7:23:05 PM
Ravivos
Status: offline
hi dirtybird, the engine is not a rotary valve type, i know that these kind of engines need a special cranckshaft with different timing in order to spin backwards.
the engine is a normal two stroke engine , XYZ26cc.
it ran flawlessly for approximately 4 gallons, always on 1:33 synthetic oil (mobile racing).
(in reply to dirtybird)
       Post #: 9
RE: gas engine reversal - is it possible ? - 6/22/2008 9:16:00 PM
yarom
Status: online
How about getting a pusher prop and running the engine in the original direction?
quote:
ORIGINAL: Ravivos
Thank you.
Raviv.
       Post #: 10
RE: gas engine reversal - is it possible ? - 6/22/2008 9:33:12 PM
Ravivos
Status: offline
it is possible, but because this is going to be a (very) experimental model, i want to have the ability to change props without waiting two and a half weeks until i recived the one i orderd.
it seems rather easy changing the location of the hall sensor in ordr to get the timing right for a CCW rotating engine, the main problem is the heat.
using a pusher prop will not solve the heat problem.
Thank you.
Raviv.
(in reply to yarom)
       Post #: 11
RE: gas engine reversal - is it possible ? - 6/23/2008 12:52:00 AM
Tired Old Man
Status: offline
The volume of air required to cool any engine is much more than most would believe, let alone the speed it needs to move at. In a hovering situation you will be forced to find a way to pump air to the engine which will present a completely different set of items to over come.
What you are doing is what modeling is all about. It's not always the easy, off the shelf, everyone does this, type of stuff where everyone has a safe haven. Someone always has to led the way and in doing so they have a lot of experimenting and research to do. You may want to look into some high volume electric mini fans. Think computer components with some specialized plenums. Better yet, brushless electric r/c motors turning fans from computer cooling systems.
Any reed valve engine is easy (easiest) to reverse running direction. Most of the piston port engines can as well. As for changing wear patterns, the only place there would be any effects would be at the bearings. Pistons and rings go in and out regardless of rotational direction.
       Post #: 12
RE: gas engine reversal - is it possible ? - 6/23/2008 3:57:35 AM
soarrich
Status: offline
quote:
ORIGINAL: Tired Old Man
True but there are side forces which change on the piston/cylinder.
Rich Border
       Post #: 13
RE: gas engine reversal - is it possible ? - 6/23/2008 6:14:34 AM
HornetFitter
Status: offline
It is never going to work . The transfer port timing (in a 2-stroke)/ valve timing (in a 4-stroke) is different when turning in reverse.
If you could redesign the engine it might be feasable, but the performance would be just plain poor.
       Post #: 14
RE: gas engine reversal - is it possible ? - 6/23/2008 6:32:27 AM
Tired Old Man
Status: offline
Tell that to the hundreds of two strokes currently running every day in reverse
(in reply to HornetFitter)
       Post #: 15
RE: gas engine reversal - is it possible ? - 6/23/2008 8:30:19 AM
Ravivos
Status: offline
Hi "old man" (name?), electric fan is a good idea, i can use a 5"-8" diameter fan with high CFM, the noise is not a problem.
the added fan might restrict the airflow for the prop,
