Trouble with Monsoon Truggy...
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> Trouble with Monsoon Truggy...
Page: [1]
Login
Trouble with Monsoon Truggy... - 6/22/2008 5:03:28 PM
Kraker
Status: offline
I am new to the RC world.....
I was tring to get my idle adjusted in just right because it was wanting to run from me while driving it. So I took it back and put in on a stand and started it. I let it run for a minute or two then reved the gas, the car then went crazy on me and the RPMs went totally out of control so I shut it down bye puting a cloth over the exhaust and the car started smoking near the fly wheel. A couple of days later I tried to work on it and my front tires would not spin or rotate. What could the problem be? It seems my idle is okay one day and not the next, now it is down completely. I have had this car for appx. 1 month and broke it in as I read to do and was told to do from experienced people.
< Message edited by Kraker -- 6/22/2008 5:04:52 PM >
       Post #: 1
RE: Trouble with Monsoon Truggy... - 6/22/2008 7:55:20 PM
vnmsgt
Status: offline
If you had smoke by the flywheel and now the tires will not turn you might have a problem in you clutch bell bearings or clutch bell. Lift the back of the car off the ground and see if it rolls then do the same with the front, if it feels locked up both ways I think it is in the clutch bell. If it is just the front then it might be in the diff. Your idle could change and how it runs depending on the day and temp. Was it idling fine and only when you run it, then it wants to run away from you? If so you might be to lean on the low speed. If at idle it does that than your idle is probably too high.
_____________________________
Caster Racing USA K8T/ZX-1R, Holeshothobbies, GO Tech engines, Fusion Fluids
Do not jump on the bandwagon...CRUSH IT
(in reply to Kraker)
       Post #: 2
RE: Trouble with Monsoon Truggy... - 6/22/2008 8:03:06 PM
Swamp3r
Status: offline
Also check for rocks or anything jammed in any of the gears, and the idle problem I`d check the small grub screws on your linkage if you reved it up and it screamed then a screw may be loose and when you rev it the screw binds. I had this happen to me on the monsoon your looking at. You may also want to take the front diff apart and have a look.
Click to see fullsize image.
Click for fullsize
< Message edited by Swamp3r -- 6/22/2008 8:09:50 PM >
HIMOTO RACING Keeps me bashing - THE REVOLUTION HAS BEGUN
http://himotoracing.com :: http://himotoracingusa.com
       Post #: 3
RE: Trouble with Monsoon Truggy... - 6/25/2008 12:47:23 AM
Kraker
Status: offline
I lifted the truggy up and tried to spin the wheels, well the front ones are locked and the back ones are fine. I will also check it for rocks in the coming days but if that turns out to be okay should I order an new diff. Also would you recommend me take this to a more experienced person around my home, a per say like when the RC club races on saturdays? ThankX again for the help you all are and have given me.
(in reply to Swamp3r)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.483RCU1
