funflier
CA, USA Status: offline
I run a Futaba 3114 on my tail as its fast, super strong, no play in the gears and relatively fast and cheap (15$ at LHS) I had a HS-50 but gave it up as its really park flyer materal and is only about half the torque (8 oz or so) of the stock esky servo although it is very very fast. It is designed for 1/2 A planes. Tried a HS 55 next but it was pricy and no better as far as performance that I could see then the 3114. Digta servos work best with digital gyros no way around that one. Waste of money less you have the gyro to work with it as a analog servo does not talk digital! Some gyros can work with both digital and analog but they are high end and if your spending 100$+ on a gyro for a 140$ helo, you may as well dump the whole cart and buy a 30-70$ digital servo along with it and upgrade to a dx7 tx and a matching rx along with the brushless motor, ESC and bigger batteries and carbon blades and cnc head and Hs-65 cyclic servos.. Didn't you buy the king ll cause it was small simple to fly and uh cheap cheap cheap...
_____________________________
King ll, 3800w/11t, cnc head, custom cnc/trextail, 43t ,Turnigy 40A ESC/UBEC bult in, Telb gyro, Dx6i w/6100e RX, HS-65 serv
