Help...Vibration issues TREX SE V2
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> T-Rex heli >> Help...Vibration issues TREX SE V2
Page: [1]
Login
Help...Vibration issues TREX SE V2 - 6/22/2008 5:23:59 PM
rftusa2008
Status: offline
I have vibration on both my trex se v2 and copter x se v2. Both are using 401, S9650, HS65MG. There is no vibration when it is hovering. The vibration stops when the blades are at hovering speed. I tried removing the blades and run the motor at full speed and did not vibrate. I'm assuming my blades has something to do with it. I have align 335 pro wood blades. I didn't mind the vibration b4 because the helios are fine when hovering but I put my Trex 450 se v2 in a heliartist 500d fuselage. It vibrates the canopy off. If the vibration is normal, I need information on how to minimize it. Thanks in advance.
       Post #: 1
RE: Help...Vibration issues TREX SE V2 - 6/22/2008 5:40:48 PM
J-MICHAEL
Status: offline
rftusa2008
Careful running your motor at full speed with your blades off, as you could overspeed your motor...If you started noticing it after a crash or so, could be a few things like main shaft, feathering spindle etc. etc. But it could just be very well your blades are on to tight...Try tipping your heli to the side, and give it a few mild shakes, the blades should just barely move very little...Hard to explain, but you don't want them to tight nor to loose...
Anyhow tell us how it goes, and I wish ya luck...The new fuselage sounds awesome...!
Have a good one,
Jeff
_____________________________
Logo 10 /Trex 500 CF /Trex 450 /Cp-Pro x2 /Cx2 /Mini-Funtana X /Typhoon2 3-D /Aero Chlngr x2 /E-Maxx,Bandit,Stampede /Evader
(in reply to rftusa2008)
       Post #: 2
RE: Help...Vibration issues TREX SE V2 - 6/22/2008 9:27:33 PM
rftusa2008
Status: offline
Thanks. I have crashed both helios but have replace the broken parts with new ones. I'm trying out new blades and see if it helps. I'll let you know.
(in reply to J-MICHAEL)
       Post #: 3
RE: Help...Vibration issues TREX SE V2 - 6/23/2008 1:16:03 AM
jfast
Status: offline
maybe your blades are out of balance?
       Post #: 4
RE: Help...Vibration issues TREX SE V2 - 6/23/2008 4:00:04 AM
MustMod
Status: offline
Had the same issue with my V2 this week. Found that at high rpm the blades were very slightly out of track. You could only see it in certain conditions, made a 1/4 turn on the rods and its all sweet. Before that the vibration was throwing the canopy grommets off. It may help, for me I need to learn to wear my glasses when setting up the heli!!!!!
       Post #: 5
RE: Help...Vibration issues TREX SE V2 - 6/23/2008 6:24:19 PM
rftusa2008
Status: offline
What rods did you do a 1/4 turn? The linkage rods. Which ones? Thanks.
(in reply to MustMod)
       Post #: 6
RE: Help...Vibration issues TREX SE V2 - 6/24/2008 1:45:35 AM
MustMod
Status: offline
Had to turn the longer rod, swash plate to flybar arm 1/4 turn. It was so subtle I could only see they were out of track in the bright sun. Hope that helps.
       Post #: 7
RE: Help...Vibration issues TREX SE V2 - 6/24/2008 3:53:08 AM
polkchop
Status: offline
Well mine was tracking bad and vibrating then I adjusted the linkages and was running like it was built by a pro. Well I soon realived that helis are not weedeaters and the vibration and tracking problem was back. I got bored the other night and got it flying again and once again was fling smooth. Then the next day the vibe was back and I am lost.
       Post #: 8
RE: Help...Vibration issues TREX SE V2 - 6/24/2008 7:20:50 AM
timothy thompson
Status: offline
GET A POSTAL SCALE AND WEIGHT THE BLADES YOUR OFF BALANCE ADD STRIPS OF TRIM MONOKOTE TO LIGHT BLADE AND THAT VIBRATION WILL GO TRY A SET OF EFLITE 400 BLADES THEY MADE MY REX SE A BETTER FLYER. AND I PUT THE REX BALDES ON THE 40O AND ITS A BETTER MACHINE GO FIGURE
(in reply to polkchop)
       Post #: 9
RE: Help...Vibration issues TREX SE V2 - 6/24/2008 3:20:55 PM
rftusa2008
Status: offline
I'll rework the linkage again and redo my blades. What buffles me is i got the vibration without even crashing. Oh well. Looks like I'll be putting on some more bling bling since I'll be working on my birds again. I got a metal skids to replace the plastic ones. I also have metal antirotation bracket to put on the trex. My trex is on a heliartist 500d fuselage. Geeez...When is this going to stop.
(in reply to timothy thompson)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.859RCU1
