ZoomZoom-RCU
VA, USA Status: offline
OK, guys. I've been fooling with this issue for over three weeks and have gotten nowhere. Thought maybe some of the experts in here might shed some light on it. I've been having trouble with reliably hand starting my Magnum XL 52 4-stroke. Its turning (or poorly attempting to) a 11x7 prop. I'm using 10% nitro and hand cranking it with a chicken stick. Here's the wierd thing. It used to start (although sporadically) after a ridiculous amount of cranking, and run ok. My goal was to get it to start more reliably. It improved somewhat and, a few times it fired very easily from the back stroke...bumping it in the wrong direction and it firing on the kickback in the right direction, and that even on the first couple flips. I'm improving I thought! Riiiiight. Anyway, after a few runs (maybe 5) like this, it has stopped starting altogether. It will sputter and turn over a few times on the crank at best, and this very reliably, but never really start. Only sputter-tick over a few turns and die. I've tried everything. I pulled the valve cover and checked the gaps, you can get a shim of flashing aluminum in the gap. I don't have a gap tetser but it seems both gaps are the same, so they probably haven't moved. I tried all of the nuts and bolts to be sure nothings loose. All seems good. There don't seem to be any air/fuel leaks. My glow plug seems to have a touch of brown film, but I've cleaned it off with no improvement. I think its due to unburned fuel from all of the sputtering no-starts.Anyway, I'm stumped. You guys have any suggestions before I pitch it off a bridge?! This is my first foray into 4-strokes, and, as it stands, I may not be coming back. TIA for the help! ZZ.
_____________________________
PAY NO ATTENTION TO THE MAN BEHIND THE CURTAIN!
